AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Does Rega rp1 turntable support dual voltage?
post #1 of 3
I'm looking at Rega rp1 turntable. Does it support dual voltage (110v and 220v)? I can't seem to find this information online.
TIA
post #2 of 3
It's an AC synchronous motor. At that price point I can all but guarantee that there is nothing in there but a motor and a switch. Even the motor upgrades require you to select the version for your country. You'll have to buy the correct version or use a converter.
post #3 of 3
None of TT with asynchronous motor can work in different power systems. Main problem is frequency - 50 vs 60 Hz. It has to be either DC motor or synchronous motor with its own generator (this later design is mostly used in really hi-end tables).
