post #1 of 1
My Optoma projector will start flashing it's standby light (orange) and it's lamp light (red) when i turn it off every single time. I have to unplug it and plug it back in and then it works fine. The fans are running during operation and it never overheats even after an 8 hour marathon. Should I just keep unplugging it or is there some issue I can correct? 206 Hours on the bulb. The fan runs for about 5 seconds after the lamp goes off and then the lights blink. Thanks.
