I guess I misunderstood your original drawing... I thought you 'had' to have a pair of saddle bag compartments under the top cabinet, to hold batteries, etc..
I also kinda assumed (although you've mentioned a couple options) that you wanted subwoofers, that you cross over at 100-150hz kind of thing, not woofers up through 2k.
My thoughts on a quad 10 were 2 facing back, and 1 facing each side all lined up, crossed over at 100-150. 20" wide just barely squeaks in a pair of 10's, and if you were to split/angle the back a bit like one of your last drawings, well that makes it childs play. Bass at low freq's is omnidirectional, so no worries on the fact that all subs are not facing the same way.
You then need a 'full range' top that can make it down to 150hz. I personally measured the 99db efficient 5" faital pro m5n12-80 with smaart. I think they are your best option. A pair of them gives you a 6ohm load, which would work well for each of the 'high freq' channels of the sure 4x100. There's an ebay seller selling for under $60 each. I know they are a bit shy on top end, but just a bit of ipod eq or anything other kind of eq brings it up to acceptable top end for music. (or you can just add a supertweeter of some kind.) I was actually impressed with their sound. Faital says it is a dedicated vocal midrange, and they are right, vocals sound very nice. It is also a neo driver and only 2lbs each. Splay your tops 90degree facing 'back' from your bike and you have about a 180degree sound field -- good for stationary, as well as riding.
On ports, 160cm2 lines up nicely with two 4" pvc ports.
On construction, I think you can get away with 1/4" bb ply with 1/4" dowels for braces from side to side to minimize any vibrations.
There really is no speaker simulation software for mac? Or, are there others that work well with windows 7?
