Originally Posted by TedX
Stumbled across this thread (and consequently demopad) last week. I was intrigued by the ability to use ip cams, so I bought the app and after a day of the "learning curve" I had an ip cam showing up. I plan on working on PTZ controls next.
I have been using a harmony 890 to control my HT stuff (Yamaha rxv2700, panasonic projector, ZWave lighting, etc.). Understanding that I will need to get a global cache device to move from harmony to demopad, I have no idea how to proceed in doing things like sending IR commands to devices.
1. Does anyone have a preferred method of finding/programming IR codes for various IR devices (e.g. ir learners)? My receiver has enough commands to keep me busy for weeks without an "easy way".
2. Has anyone found a good method for controlling ZWave via demopad?
Your Yamaha receiver can be network controlled by IP, codes are available for it.
Most IR codes are available check RemoteCentral .com Demopad has a tool to convert Pronto codes.
Can't answer on ZWave.
