Originally Posted by
mashenden
I would like to control my A/V equipment using an app and an iTach WiFi-2-IR unit, but rather than using an Apple device (iPod/iPad/iPhone) as the user interface (aka the "remote"), I want to control things using my wireless (802.11) laptop PC.
Is that an option with Demopad? In other words, does Demopad support designing a custom button layout with macros that can be used on a PC?
Fulltopuk
Look at Touch Control. I think that does what you require.
mashenden
I will take a look. Thank you.
Thanks to input from mdavej and XARiUS, I found what I was looking for in terms of the technical details needed to control a Panasonic DMP-BDT110/210/310 unit
using IP over a 802.11 network. Then I successfully controlled my device
using a laptop or iPxx device thanks to Fulltopuk as well as TouchControl after some tweaks on HTTP POST made by its developer.
The technical details on the command format (again thanks to mdavej and XARiUS) can be found in the following post:
http://www.avsforum.com/avs-vb/showt...5#post21491715
My TouchControl device layout has been designed and is available at that site, if needed:
http://www.touch-ir.com/. I have no affiliation to TouchControl other than I am a very impressed user (more on that in this post
http://www.avsforum.com/avs-vb/showt...5#post21491535).
Also I am not posting this here to bash Demopad, but instead to encourage the development of a side app that can be used on a laptop PC as well as give direction to people searching for this as a firm requirement. If this is or becomes available in Demopad I would like to know.
NOTE: Please note that STOP does not work on my DMP-BDT110 and I am looking for a command for the Display button. Also, if anyone knows of any Status commands for the Panny DMP-BDTx10s, that would be nice to know as well.
