Originally Posted by Karyk
I'm not getting all of my channels again from Comcast. Before it was a filter left over from my Limited Basic days. This is slightly different. For one thing, it seems to affect different channels at different times.
In WMC I get a no signal message, but if I go to the HDHR programs, it shows 100% signal, but in the channel name it adds "[No Data.]" If I try to go to a channel I'm not subscribed to, I get a message to that effect.
Any idea what could be causing that sort of problem? The first Comcast rep I spoke with didn't have a clue--he told me I had upgraded to "Limited Basic" back in September, and wanted me to unplug my HDMI cable as part of his problem solving. The second one knew more, but still couldn't help me.
I found this thread over at Silicon Dust's forums, and the OP's screenshot looked exactly like mine (except my signal was 100% strength and quality) and the symptoms the same. I updated my software/firmware and it fixed the issue (so far).
http://www.silicondust.com/forum2/viewtopic.php?f=44&t=14564
I asked Jason about the thread and he said it was probably a channel assignment change and that a May 2012 software fix should fix it. I hope that's right, because it doesn't quite sound right with the problem having been intermittent. But again, so far, so good.
