Originally Posted by Foxbat121
No, since he is going to remove the cablebox and save another splitter, the segment of the coax that goes into that TV location will be disconnected from the rest and can be used as direct connect for MoCA. If you want to inject MoCA into CATV coax network, you will need a MoCA fiter to prevent the MoCA signal getting back to the cable provider. But a disconnected coax cable doesn't have any of these problems.
I've not gone down the road of an "extender" yet so it is all new to me. I know there is info here on AVS but HoleeSheet I don't I will live long enough to read it all.
As related to Xbox I found this on Ebay:
Xbox 360 $99.00
In brief, how does it hook up and what is used to view TV and start/view recordings?
I can build another HTPC if that makes life simpler.
