Originally Posted by
stamina1914
So are you guys happy with your product. I am in the middle trying to purchase a tuner to replace my DVR Boxes. I purchased a similar question on the other major TV tuner forum. So would you buy your product again?
I must say that I am a little disappointed that HDPrime can only record 3 shows at once, but I am also glad to see that this forum has sooo many less posts about their product than the other guys. While my assumption may be incorrect, to me it shows that the prime MIGHT be a more reliable system.
A lot more Prime support is funneled into their actual forum site, and Ceton has more frequent presence in this particular forum which leads to more posts for that reason as well. Also, the InfiniTV thread started before the thing was even released, and that was still a year before the prime was released
I feel like currently they are both well supported and have a lot of users here. Some of us use them daily without issues and never comment. I've never had a problem with the Prime. I'd probably never have had any problems with the InfiniTV. I try a lot of software and that is usually where problems come up, nothing typically is wrong with the tuner. I like the networked box over a USB or PCI tuner. I've used the prime's tuners on a SU4100 W7 laptop, main i5 server/htpc, g630 OpenELEC box, i3 W7/OpenELEC box, and Nexus 7. I probably wouldn't have attempted this with a PCI tuner. I don't believe Ceton allows you to access a pool of tuners (I've not read up on it recently), so you have to bridge your tuners to different setups
Pick whatever suits your particular needs the best
If I had it to do over again, I'd still buy the Prime (I would also avoid paying retail, the same way I do with almost everything)
