Originally Posted by Multimediashtick
Using unmanaged giga switches seems to be the best method for networking between devices. (If you have a D-Link router you need to enable Multicast Streams within the advanced tab of router settings.) Ensuring that signal strength that the prime has is peak will increase stability (either a visit from your provider to adjust or add a signal booster just before the tuner). Many have reported seeing weak network signals on the xbox and have no interuption and have the report disappier within a few seconds, if this happens you might consider disabling the notice within xbox.
I just read this post and so I checked my settings on my dlink dir-601 and found out that I did not have multicast enabled but I have not been having anyproblems with my set up. Should I enable it and see if anything changes?
