Originally Posted by
signcarver
I've been seeing a lot of laptops and all in ones use displayport... but couldn't find out for your model. My point in "correcting" sammy2 before is that your monitor may indeed be hdcp capable but use a displayport which WMC says isn't compliant even though it is (if connected to the right monitor), so just asking that question wasn't quite enough as even if you truthfully said yes to being hdcp compliant, it still may not work as wmc thinks you are not. It may also be that they decided not to have an hdcp compliant monitor. This sometimes happens with laptops as for most things that require hdcp, there is an exception for an integrated display so it may save them a few pennies. However WMC and cablecard tuners don't have this exception. In this case, you can only view protected content when connected to your hdmi port... also make sure the monitors are not cloned but I didn't mention this before as you mentioned dragging it to the monitor connected to the hdmi port so I thought it was obviously extended.
One other future possibility is with the new dlna/dtcp-ip firmware... right now there is nothing to record and integrating guide data is probably non-existent, but it may be possible for CyberLink SoftDMA and/or powerdvd 12 (full paid version, trials don't support dtcp-ip) to play these channels (there is currently a "bug" preventing powerdvd from working but SD says they are working with cyberlink to resolve this). I'm not positive but I believe the dlna spec allows for the exemption on integrated displays as I don't think most phones and tablets have hdcp compliant monitors (though they may be exempt by the resolution of the display).
This is the laptop which is basically just an asus zenbook ux31a with touch capability. The displays are not cloned as the built in display is full hd 1920x1080p IPS panel (beautiful display btw) which does pass the digital cable advisor test, fwiw and the external device is a dell 2408wfp ultrasharp at 1920x1200.
Is there a way to check if the built in display is hdcp compatible? On control panel the built in display panel is just listed as generic display device. On the asus website I did not see a specific display device INF.
EDIT: Here is my EDID info:
EDID BYTES:
0x 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 | 00 FF FF FF FF FF FF 00 0D AE 48 13 00 00 00 00
10 | 16 16 01 04 A5 1C 10 78 02 A7 05 A6 56 54 9B 26
20 | 0C 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30 | 01 01 01 01 01 01 36 36 80 A0 70 38 20 40 2E 1E
40 | 24 00 1A A5 10 00 00 18 24 24 80 A0 70 38 20 40
50 | 2E 1E 24 00 1A A5 10 00 00 18 00 00 00 FE 00 43
60 | 4D 4E 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
70 | 00 4E 31 33 33 48 53 47 2D 46 33 31 0A 20 00 79
80 | 00 00 3A 10 00 00 3A 10 9C 00 3A 10 E0 B1 18 00
90 | A0 DC A9 77 FF FF FF FF DC B1 18 00 E8 B1 18 00
A0 | 00 80 00 00 00 00 3A 10 00 00 3A 10 00 00 3A 10
B0 | FC B1 18 00 14 DC A9 77 00 00 01 00 00 00 00 00
C0 | 00 00 00 00 00 00 00 00 0F 6B 6E 85 08 B2 18 00
D0 | 97 3B 77 77 00 00 3A 10 1C B2 18 00 98 5A C7 02
E0 | 00 00 3A 10 19 51 C7 02 00 00 00 00 58 B2 18 00
F0 | 16 52 C7 02 00 00 C5 02 00 00 00 00 5D 52 C7 02
Edited by ymarker - 1/27/13 at 9:11am
