you will generally need OOB lock before you can get it paired. I think I remember one area actually using an "in band" (as opposed to "out of band") activation scheme but am not familiar with it just remember reading that some area used it. Usually its an FM trap or other filter that interferes with this when there are problems with the OOB signal (usually around 75Mhz sometimes its just the signal. If one prime is working and the otherone isn't, It could be the tuner used for OOB in your prime is faulty and will require a return. I strongly suggest opening a ticket with SD as they might be able to determine if the OOB tuner is faulty or if it is just your signal.
post #991 of 1487
1/31/13 at 7:57am
