So I'm the proud owner of 400sq Ft of 2" 3pcf rigid insulation. They came in 2by4 sheets, 10 to a pack.
Here's the pile.
I like that it's darker in color. Check it out.
I decided to go with the typical corner traps with the 3pcf material. Cutting the 2 by 4 sheets into quarters gives me 4 triangles that measure 24x24x37. I'll stack these about 78" high on each side.
Here's my layout for the space behind the screen.
In other news, I'm done with the first mud/taping layer and started sanding. My shoulders hurt!
Edited by stevegravley - 6/29/12 at 10:33am
