I'd like to run my acoustics plan by you and see if anyone objects to anything or has any ideas for improvement.
What I'd like to accomplish is to provide some standard practice acoustical treatments to baseline my room's acoustical performance. Beyond this plan I can add/tweak what I've already done to address issues that crop up.
As the room stands, rocked, the sound in the room is very comfortable. There's little to no echo. That may change with mud/paint, but I don't think by much (I could be wrong). So, I'm pleased with that. I did the clapping test and there is nothing.
Here's what I'm planning on currently:
I don't have any plans yet for the back of the room, so if you think I should put something there, please let me know!
I figure the cost of this will run me about $300-$350, and I'm hoping I'm not wasting my money.
Any feedback is appreciated! Thanks!
- Linacoustic or equivolent treatment along the front wall. I don't have a cover planned for the linacoustic. Do I need one?
- I will build triangle corner bass traps in the front behind the screen using stacked and cut R30 insulation. My structure will be made from cheap-o 1by2's and will have bracing in levels so the insulation doesn't compress. Then I'll cover it with a black muslin or other cheap black mostly transparent cloth.
- I will build two acoustic panels on each side to handle first reflections. You can see the placement in my design mockup. The frames will be built to support 2" OC703 with a 1" air gap to the wall. Then I'll cover it with a custom printed cloth from Spoonflower (or whatever that place is called). The panels will be about 3 feet by 5 feet.
