Originally Posted by jnabq
Yep, the 6010 had the same "backward lcd alignment menu operation", when mounted upside down, and the new v104 firmware for the 5010/6010 addressed it.
Posted the DIP settings in the 5010/6010 thread as well. Hope you can follow it.
You get to this information with the remote:
1) Hold down MENU for 8 seconds, release
2) Hit ESC twice
3) A menu of information appears
4) Hold down MENU another 8 seconds, release
5) Hit ESC twice
Now you should be at a screen where you can arrow up and down, and for each DIP switch see the bit settings of that one.
DIP SWITCH SETTINGS Epson 6010 FW v104
O=GREEN X=BLANK
DIP SW1 [BIT0 O/X] [BIT1 X/O] [BIT2 X/O] [BIT3 O/X] [BIT4 X/O] [BIT5 O/X] [BIT6 X/O] [BIT7 O/X]
DIP SW2 [BIT0 O/X] [BIT1 O/X] [BIT2 X/O] [BIT3 X/O] [BIT4 X/O] [BIT5 X/O] [BIT6 X/O] [BIT7 O/X]
DIP SW3 [BIT0 O/X] [BIT1 X/O] [BIT2 X/O] [BIT3 X/O] [BIT4 X/O] [BIT5 O/X] [BIT6 O/X] [BIT7 O/X]
DIP SW4 [BIT0 X/O] [BIT1 O/X] [BIT2 O/X] [BIT3 X/O] [BIT4 X/O] [BIT5 X/O] [BIT6 O/X] [BIT7 O/X]
DIP SW5 [BIT0 O/X] [BIT1 O/X] [BIT2 O/X] [BIT3 O/X] [BIT4 O/X] [BIT5 O/X] [BIT6 O/X] [BIT7 O/X]
DIP SW6 [BIT0 O/X] [BIT1 X/O] [BIT2 O/X] [BIT3 X/O] [BIT4 O/X] [BIT5 X/O] [BIT6 O/X] [BIT7 O/X]
2) Hit ESC twice
5) Hit ESC twice
O=GREEN X=BLANK
Thanks a lot !
I compared these with the ones on my 3010 and they look identical (after I enabled the LCD alignment)
I guess there is nothing much and it may be risky to touch others.
, meybe thay fixed they erros.
...bet cnn is way more accurate.
