AVS › AVS Forum › Audio › Receivers, Amps, and Processors › AV Receiver with Dual HDMI Outputs
post #1 of 8
Fellow Users
I am looking to change my Stupid AVR 4310CI (Network Card keeps failing and system hangs) to a different AV receiver. I am looking for recommendations on a new AVR which can do 2 or more different HDMI outputs with separate Select-able sources. meaning I am trying to power 2 TV's with the same receiver and hopefully both can see different sources. Kindly help to make my decision.
post #2 of 8
That's what I'm trying to do. Same receiver/ 2 HDMI output sources. I've been looking real close at the pioneer SC-57 and the Denon 4311ci. Here is my confusion: Both have 2 HDMI outputs, but the BIG question that I need an answer is.... Can those outputs send 2 different signals??? So if I'm in the living room watching HD TV, and the kids are in the room watching a 3D film. Which receiver can do that??? I've read a lot and all they say is that they have 2 HDMI outputs, but I'm kind of confuse still. Any help would be greatly appreciate it.................. thanks...........
post #3 of 8
No.
post #4 of 8
Originally Posted by ankur1234 View Post
Fellow Users
your "decision" is easy, because nothing will do what you want...
post #5 of 8
thanks for the reply........
post #6 of 8
Any recommendations between the Pioneer SC-57 and Denon 4311ci ??? And why??? I know there is lots of posts out there, I've nearly read them all, but most are like Denon is better because I own one or vice versa. Thanks for the input
post #7 of 8
the 4311 due to the superior dsp...
post #8 of 8
My vote as well go with Denon as Denon 4311 has got an better DSP & good MultiEQ
