Here's some craziness for you. I think I'm punchy.
Thinking through the coffered ceiling lighting. Each section will be lit up by rope lighting pr LED strips. I know this has been solved before. I only have two switches to to coffered lights. I was thinking that I could drill a hole through each section to run the LED rope light from one section to the other, assuming there is no issue doing so. Assuming you can run the light through the sections, the challenge is rope light comes in 150 ft rolls, so I'll need to do the two circuits sections efficiently. I did a little white boarding at work and came up with two ways. The first would work length wise. I have not calculated the second.
First you start with the coffered ceiling. Ignore the switch locations.
The red line is on continuous rope light. Ignore the breaks.
The blue line does the other sides, Again, ignore the breaks.
Combined, they look like this:
The other option is to do half with one and half with the other:
Again, not sure either option is code compliant.
The bottom option actually makes more sense if you want to turn one half of the room on and not the other. Not sure I'd do that, but it's an option. The first seems to have less overlap. I'm sure there may be other options and maybe some efficient.
Another option (would have to check code compliance) would be to have six outlets tied to one switch and have each coffer have it's own section of rope light plugged into the outlet (hidden by crown). Times two for the other side.
Any comments?
Bud
Edited by chinadog - 7/3/12 at 7:05pm
Any comments?
Bud
The E-node control is too much for my budget, for sure. For me, the multiple colors and the control options aren't high on my list, heat control is obviously. I didn't use LED rope light in the last build and I want to make sure I'm using LEDs this time around.
