Trinnov allows the remapping to be deactivated. Was that tried?
. Discerning DAC differences is very hard even with the two playback systems being identical. In your situation which such wide variations in signal processing and system equalizations, it is a complete impossible thing. There is no way to characterize EQ differences as subtle and DACs as not.
,How do you think Audyssey Pro in your current set-up compares to what you heard from these devices.Has the "sky opened up to the God's"
sort of speak, in comparison to Audyssey Pro?
. Fortunately he has a few 18s up front and multiple 12s in the columns which helped make it sound much fuller than the small speakers might otherwise. This is also where this particular system was a real workout for the room correction systems as some of the subs were working up past 100Hz. This can work well, but smooth response at the listening position is critical.
