Originally Posted by sdurani
What is still helpful, like all the research that Harman publishes, is the broad conclusions reached by testing: smoothness of frequency response and shape of target curve turned out to be the two factors that had the highest correlation with listener preference. I don't see that as "the trouble with that test" but instead the most encouraging aspect of it.
Well I did say
That further clarifies what "perceptually flat" means, but seems to leave open the possibility that the result is objectively inaccurate, i.e., if some live sound were produced in a given room, then reproduced with speakers EQ'd to perceptually flat, it might sound better but different in spectral balance than the original.
Curt can probably explain how Trinnov Surround distributes sound to the Heights.
The source signal is losing resolution when the volume is reduced (this applies to analog or digital volume controls), but it does not matter since the noise floor (or the quantization floor) of the playback system is not increasing.
