AVS › AVS Forum › Audio › Receivers, Amps, and Processors › NAD T 747 keeps turning off randomly
post #1 of 2
Hi
I've had this amp for less than a year and it's been working seamlessly until today where it keep turning off while we're watching a movie, say, every 5-10 minutes. It's not running hot and no one's butt is sitting on the remote. I looked online, in the manual and on this thread for an answer but to no avail.
Any help would be greatly appreciated!
Cheers
Alex
post #2 of 2
check the speaker wiring to make sure no loose strands are touching another terminal. Are you using banana plugs or bare wire?
