Media Center Studio is an excellent application that allows you to completely customize the look of your WMC interface including adding and removing buttons and options.
This is just one example of a before and after picture from my blog of what MCS can do to the appearance (edit: apparently must be a blog member to see the pictures):
Before:
After:
The developer for MCS has abandoned the software but thanks to Josh3693, JoshFink and myself we have figured out a way to revitalize this valuable piece of software.
First you will need this file located at my blog (www.assassinhtpcblog.com)
Zipped Directory
Also if you want a txt file of these instructions I have made them available here.
Next, unzip the file
Make sure you have "show hidden folders" enabled under the folders option in your Start -> Control Panel menu.
Now move the unzipped directory to C:\\users\\*your_user_name*\\Appdata\\local\\Apps\\2.0\\mcst ..tion_e7ba95bf63da1a4e_0000.0000_8295f17bcae6f0ac where "mcst..tion_e7ba95bf63da1a4e_0000.0000_8295f17bcae6f0ac" is the name of the directory that you just unzipped and pasted into that folder.
Finally run the executable : Media Center Studio.exe file.
I have a complete guide on how to use MCS over at my blog as well as 18 themes with instructions on how to use the themes.
Welcome back Media Center Studio!!!
Alternatively daspannerman at the Media Browser forums has created an installer file. I haven't tried this yet but will do so very soon.
LINK
Before:
After:
Zipped Directory
LINK
