..........................................Revue GTV 2.0 TIPS
.....................For Updated Google TV Tips (sticky) & Revue Tips (sticky) --> CLICK HER!
.....................................Revue Tips were originated from this thread!
Netflix:
Bookmarks:
Application info:
Chrome:
TV Mode
Home Screen:
Settings menu:
USB Drive:
Crackle - Vevo:
Video:
Audio:
Harmony Components:
IR:
Keyboard
Airplay Apps
Modem/Router
Troubleshooting:
If you have tips, share & Post.
Cheers!
Netflix:
Tip: Netflix now supports streaming of available HD contents in 1080P / 5.1 surround Sound.
Tip: To quit Netflix/Pandora Apps, press and hold the [esc] key till the dialogue pops-up!
Tip: To Avoid Netflix Error Messages
..We're having trouble playing this title right now. Please try again later or select a different title...
..... Loading, Please wait . with a full Red bar displaying.
Press (repeatedly) the [Back] ⤺key to exit all opened Apps (in the background)and return to Home screen - before lunching Netflix App.
Or, Reboot Revue (Press Ctrl + Alt + DEL) - before Launching Netflix App.
Tip: Netflix issues,
From All Apps select Netflix App Press & Hold [OK] key - select Application info' from menu - >Force stop / Clear data - reboot - sign-in to Netflix Account.
Or
Go to Settings > Applications > Manage Applications > Netflix >Force stop / Clear data - reboot - sign-in to Netflix Account.
Tip: Deactivate (unlink) Netflix Account - wait 30min - reboot Revue - sign-in to Netflix Account
Tip: To Deactivate Netflix Account,
Go to www.netflix.com - Log-in to your Account >'Your Account & > Help' > 'Manage devices > Deactivate (takes about 30 min) - Reboot - sign-in to Netflix Account,
Or
From Revue's keyboard - Press (without delays) Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
Deactivate - Reboot - sign-in to Netflix Account
Tip: Reboot Modem/Router, after the reboot-up process (Modem first wait then Router second wait - Reboot Revue. (or have Revue unplugged from power before Rebooting Modem/Router )
Change Router channel /frequency (for N Routers)
Connect directly to a modem - bypass the Router.
Try changing DNS in Router - to Google DNS ( 8.8.8.8 ) or open DNS ( 208.67.222.222 ) - this option is for advance users.
Tip: Reboot Revue,
Unplug it from power (wait 30 sec.) re-plug it.
Tip: To Do Factory-Reset -three options to choose from -> .
Go to Settings - select Privacy & Safety - Select Factory data reset.
Lunch Chrome - press [Option] key - from the menu select Setting' > Reporting > Factory data reset (erases all data on device).
Hold down the button on the back of the Revue until the TV-logo comes up. (it may takes about 40 seconds) -> then the progress bar will display... (Factory-Reset will erases all data on device - like new Device).
Tip: Create a new Google Account at sign-in, after Factory-Reset
Tip: Turn OFF All Connected Devices (TV-STB-AVR-Modem-Router) - unplug /disconnect, Power cords & HDMI cables from All Connected Devices - Wait 10 min - plug Power cords & Power-up Modem/Router ( see above) - wait 5 min - reconnect HDMI cables - plug Power cords & Power-up all other Devices.
Tip: Adjust / Manage Netflix Video Quality,
Sign-in into your Netflix Account.
Click on Your account & Help.
Click Manage video quality.
Select Lower quality.
Or
Or
Tip: Reboot Revue,
Bookmarks:
Tip: To Delete bookmark, Select the bookmark - hold down the [OK] key till the option-dialogue pops-up.
Tip: To add a bookmark to Home Screen, While in Chrome - select the bookmark - press the [Favorites key] (Star controller key) - from the dialogue select Add to home screen - go to Home - press the [Option] key (the dash key located between [Alt] &[Ctrl])- from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the bookmark.
Tip: To Add a whole Bookmarks folder to Home Screen
Download and installed BookmarkSB App from Market.
While in Home press the [Option] key (the dash key located between [Alt] &[Ctrl])- from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the bookmarkSB. (btw, bookmarkSB tip was posted by jTV ).
Tip: To find a Bookmark/Shortcut - was saved while in Chrome by adding a bookmark from the option Add to home screen - will Save/place the bookmark/Shortcut in All Apps Folder/drawer - to find it, from Home Task-bar select All Apps icon.
Tip: To find a Bookmark- was saved while in Chrome by adding a bookmark from the option Add to bookmark folder - will Save the bookmark in bookmark Folder- to find it, go to Chrome - press [Option] key - select Bookmarks from menu.
Tip: To edit a bookmark - press & hold [OK] key to display edit-menu.
Application info:
- From All Apps select App Press & Hold [OK] key - select Application info' from menu - select App.
- Or,
- Go to Settings > Applications > Manage Applications > App.
- Or,
Chrome:
Tip: Chrome Settings for Adobe Flash /Privacy / Password-word / Security,
Go to Chrome >press [Option] key > Settings > Advance settings > select under the Hood > Privacy
Tip: To change Fonts,
Go to Chrome >press [Option] key > Settings > Advance settings > select under the Hood > select Customize Fonts
Tip: To close Chrome - Press [Ctrl] + [W] keys
Tip: To Refresh Page - Press [Ctrl] + [R] keys
Tip: To type URL - Press [Ctrl] + [T] keys
Tip: Bookmark menu - Press [Ctrl] + [D] keys
Tip: To Clear Browser Cookies/History/ - Press [Options] then [s] keys
Tip: To Search within a Page - Press [Ctrl] + [F].. keys (press controller [Previous] key to exit)
TV Mode
Tip: To Move/Adjust Picture-in- Picture - Press and Hold [Picture-in- Picture] controller key to display option menu.
Home Screen:
Tip: How to Place an App or a shortcut to Home Screen?
- By replacing one of the seven Apps from Revue Home Screen task bar.
- go to Home - press the [Option] key (the dash key located between [Alt] &[Ctrl]) - from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the Appk/shortcut.
Settings menu:
Tip: To display Settings menu,
- Press [Options] key then Press [s] on the keyboard while in Home screen.
- Or
- Via the Settings App.
- Or
USB Drive:
Tip: Revue Supports USB Drives formatted in NTFS & FAT32 Format.
Tip: To Safely Unplug /Remove USB Drive - Unmount it
- Press [Options] key - Press [s] key - Select Storage' - select unmount .
- Or
- Go to Settings - Select Storage' - select unmount .
- Or
Crackle - Vevo:
Tip: To install Crackle -web, type crackle in search App - select the link crackle-Watch free Full (w/Chrome icon) - bookmark it.
Tip: To add Crackle-bookmark/shortcut to Home Screen:
While in Chrome Select Crackle-bookmark -Press the [Favorites key] (Star controller key) - from the dialogue select Add to home screen - go to Home - press the [Option] key (the dash key located between [Alt] &[Ctrl]) - from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the bookmark/shortcut.
Tip: To install Vevo -web, type Vevo in search App- select the link crackle-Watch free Full (w/Chrome icon) - bookmark it.
Tip: To add Vevo -bookmark/shortcut to Home Screen:
Video:
Tip: Black Screen at start & after reboots - if STB /cable/satellite box is disconnected!
Press [Home] key.
Press [Option] key - from menu select Home and All Apps settings' - select startup applications' - select None'. (you may replace [TV] icon in Home screen if not need it).
Tip: Annoying menu at start & after reboots (asking to setup STB) see above tip.
Press [Home] key.
Audio:
Tip: If no 5.1 surround sound when STB/ cable/satellite Box. Connected thru Revue -GTV 2.0 & AVR. Make sure the STB/ cable/satellite Box Audio system setting is set to Pass Through (NOT set to Auto or Lpcm) Assuming HTS connection as follow: STB >HDMI>Revue>HDMI>AV receiver>HDMI>TV
if the cable channel broadcasting in 5.1DD - correct sound field will be heard from All 6 speakers connected to AVR (transcended/5.1 PCM @ 48 KHz)
if the cable channel broadcasting in 2.0 DD correct sound field will be heard from LF&RT speakers + Subwoofer speaker connected to AVR (transcended/2.1 PCM @ 48 KHz). .
To change Audio system setting on the STB Cable box:
The STB Audio system setting menu (secret menu) can be accessed by turning Off > pressing menu on remote or front panel (Refer to the device owner's Guide for instruction).
For STB Motorola DCX-xxxx/DCTxxxx - To change Audio system setting (secret menu) - From the STB remote Control (Cable/satellite supplied remote) turn ON the STB then press [On/Off] Power button then press [menu]button (in quick succession) - a white system menu will display on the TV - Scroll down to: Additional HDMI Settings > Press [Ok] > Scroll down to: Audio Output: > Press [Ok] > toggle between Auto/Lpcm/ Pass-Through > Select Pass-Through - Press [ON/Off] to exit menu - press [ON/Off] again to turn On STB.
For STB Motorola QIP7232- To change Audio system setting (secret menu) - From the STB remote Control (Verizon-supplied remote) turn ON the STB -Press [On/Off] Power button then Press [OK] button then press [menu] button (in quick succession)- a white system menu will display on the TV - Scroll down to: Additional HDMI Settings > Press [Ok] > Scroll down to: Audio Output: > Press [Ok] > toggle between Auto/Lpcm/ Pass-Through > Select Pass-Through - Press [ON/Off] to exit menu - press [ON/Off] again to turn On STB.
Note : take extra caution when system menu is open & avoid change any other settings!! (Refer to the device owner's Guide for instruction).
Tip: Digital Optical Audio Cable, if connected between Revue and AV Receiver - the audio option of Stereo (2 channels PCM) or 5.1Dolby Digital (DD bitstream) can be selected - go to Settings > Picture & sound >Optical audio output.
Harmony Components:
Tip: Can't Control TV /AV Receiver / STB from Revue's keyboard,
- Remove Component (TV/AVR) from Revue - go to Settings > TV& AV Receiver > Select TV or AV Receiver > Remove - Yes
- Remove Component (STB) from Revue - go to Settings > TV Source > Select STB > Remove STB - Yes
- Reboot Revue, Press Ctrl + Alt + DEL
- Re-program Components.
- Place IR Blasters as needed.
Turn OFF HDMI Control from Television-set, AV Receiver & STB (to avoid conflict).
For example;
- Sony TV, turn OFF Control for HDMI, go to Home >Settings > Channels & Inputs > HDMI Settings > Control for HDMI > OFF.
- Samsung TV, turn OFF Anynet go to Menu > Media Play >Anynet+HDMI-CEC > Setup > Anynet = OFF, Auto Turn OFF=No.
Note: Revue doesn't send HDMI control signals to HTS (TV/STB/AVR) via HDMI cables (HDMI-CEC) - All control signals are send from Revue via IR signals.
For example;
IR:
Tip: For IR interference Harmony / universal Remote Control - try this,
Take an old 3.5 diskette apart, remove and discard top and bottom shells and woven liners, then take the dark flexible plastic magnetic disk out and cut large piece from it (discard the Hub), bend it 90° and place it to cover Revue IR window, use clear-tap to tap around it.
Make sure you cover the entire IR window (top & front) & Point the remote directly to Revue.
The dark flexible plastic magnetic disk acts well as a filter, especially when TV or other devices censers active. However, any IR remote with Revue will act slightly sluggish!
Tip: IR Blasters, will extend the IR signal - it's needed, if any of the connected devices of HTS (TV/STB/AVR) to Revue are not responding when pressing [Power] - [Volume]-[input] keys on Revue's keyboard. (it can be connected regardless! - No Con's).
Revue has a strong built-in IR Blasters that will send IR signal the IR receiver of the connected devices of HTS (TV/STB/AVR) any time [Power] - [Volume]-[input] keys on Revue's keyboard are pressed - some users may place Revue in a cabinet or place the TV distance away were the IR signal can't reach/bounce - the IR Blasters comes handy - connect it to the back of Revue and place it in front of the IR receiver (IR eye) of TV /STB/AVR - (you may connect more IR Blasters via splitters & extension cables).
Note: Revue doesn't send HDMI control signals to HTS (TV/STB/AVR) via HDMI cables (like Anynet) - All control signals are send from Revue via IR.
Tip: Adding discrete IR codes to Harmony Remote Control . (Exclude Harmony 300)
Log-in to your Harmony account on members.harmonyremote.com, then go to THIS link. You don't have to learn a button first. You create it on the fly. On that page, first click "Select an Active Device" and pick your device. Then click "Manual", paste your hex into the Data Value box under Pronto, and then click "Process". If it's valid, click "Next' and you get the option to name your new command and click "Add". (thanks to first poster).
Keyboard
Tip: Keyboard Pairing, turn OFF Keyboard - Reboot Revue -
- Press the button on the back of the Revue for One sec - Follow On-Screen prompts.
- Change keyboard battery -(see step above)
Airplay Apps
Tip: Airtight App for GoogleTV - will allow users to stream content from the iPad or iPhone using Airplay
Modem/Router
Tip: For Wireless (WiFi ) or wired (Ethernet) Connection issues,
Unplug power cord from Modem/Router & Revue.
Re-Plug power cord to Modem, wait 5 min.
Re-Plug power cord Router , wait 5 min.
Re-Plug power cord to Revue.
Tip: For wired (Ethernet) - Connection issues,
Unplug the Ethernet cable & power cord from Revue.
Reboot Modem/Router, ( see above steps)
Plug the Ethernet cable to Revue.
Notes: if all devices (Modem/Router/ Revue) are plugged into the same Power-Strip' - turning On/Off The Power-Strip' may reboot all devices at the same time.
More Tips - Connection issues,
Disable MAC address filter on Router.
Make sure the Router is configured to the Primary Network WiFi connections ( Not Guest Network) - Revue may not support Guest Network.
Temporarily disable the Guest Network on Router.
Voice-Modem/digital phone device - connection failed... issues - add/install an additional Router - (Modem/Gateway with Voice/digital phone device > Router > Revue).
For Cable Modem - Connect the Coax cable to the cable Modem through USP to prevent signal spikes - ( Uninterruptible power supply (UPS) with Coax Protection (RG6) and Automatic Voltage Regulation (AVR) is recommended!)
Perform a Factory-Reset on the Router and re-configure it.
Try changing DNS in Router - to Google DNS ( 8.8.8.8 ) or open DNS ( 208.67.222.222 ) - (this option is for advance users).
Troubleshooting:
Tip: To Reboot Revue,
Tip: Device/App issues,
Clear data /cahe/ Force exit - from App (see Application info tip above)
Remove the last App was installed.
Factory- Reset.
[b]Tip: Turn OFF All Connected Devices (TV-STBs-AVR-Modem-Router) -Unplug /disconnect, Power cords & HDMI cables from All Connected Devices - Wait 10 min - plug Power cords & Power-up Modem/Router - wait 5 min - reconnect HDMI cables - plug Power cords & Power-up all other Devices.
Tip: HDMI handshake issues - HDCP issues -Black Screen - Green Screen -Purple Screen - Audio without Video,
Change HDMI cable - Swap cable ends - Plug cable in a different input - cycle between HDMI inputs.
Note: Turn OFF all connected devices, unplug Power cords or turn OFF Power- strip (if in use) - wait 10 min - if the TV red power light still On wait until it goes OFF, before plugging or unplugging any HDMI cables.
Tip: To Performa Factory-Reset -three options to choose from -> .
Tip: After Factory-Reset Harmony Components issues - Re - perform Factory-Reset, this time create new Google Account at sign-in.
Factory- Reset.
Cheers!
