Originally Posted by Don Landis
Joe- Just to repeat:
Using twin cams in 2D mode to create a left and right eye 1080 24p x 1920 and then pair, correct in Vegas- output to my work flow TB Full then generate a Blu Ray disk at 1080 24p in PD10 as test 1
Test 2 was shoot with TD10 in normal 60i MVC mode and render same work flow as test 1 to make a BD-RE in PD10
I could not say there were ANY detectible motion artifacts in either test when viewed on my Sony VPL VW90ES projector ( 240Hz ).
On my Vizio (60Hz), both tests suffered the same level of less smooth motion.
I'm not talking stuttering or hesitation as there was none of that throughout. I'm talking about constant less smooth look.
Not sure I posted this but since, I viewed a commercially made Blu Ray in the player and viewed on the Vizio and it had the same degree of not so smooth motion as my PD10 made BD-RE tests.
My conclusion was that the latest workflows and software versions produce a product that is equal in quality to commercially made 1080 24p 3DBD with respect to motion. I agree that technically, not having to do a conversion from 1080 60i to 24p is better, but I don't think it results in obvious improvement visually. Maybe this would be a different story with the JVC MVC format but it doesn't matter with the TD10.
I'd like someone else to do the test to compare but I think only Frank here has the capability to set up a pair of JVC's in 1080 24p twin cam mode. Plus, his JVC's suffered a defect as I recall. If someone has a Pro version that shoots in 24p we could also do it that way. But, I would only trust the results if it was done in double blind testing.
OK, I'll have to try that workflow. The problem is that I have yet to upgrade to Vegas 11 - too much other stuff going on with family, holidays and organizational issues with my video. I'll do the upgrade before Christmas.
The Magic Memories and You video needs to be fixed. The original file looks fine here but the upload version looks like the 3D is backwards but the swap doesn't fix it. They keep changing the upload interface so it's probably something I did wrong.
Got your warning just in time as I was planning to upgrade both my systems in the morning.
