I will disagree that rendering to extremely high bit rates from sources that are lower bit rate is a plus gain. You don't gain in quality, rather you gain in noise which is not desirable. You can't get higher quality video by taking a low bit rate and rerender to a higher bit rate.
Hmm? I never said it gains quality...
I take it the Vegas MS does not have the {Tools/ render to new track} method so you're stuck with a lossy compression.
Movie Studio
does have the render to new track option. I used it to render the MP4 file referred to in post #241. I was asking if there was a benefit to rendering to a new track versus rendering via the "Make Movie" button. It would appear the only advantage is that render to new track brings the clip into the project automatically after finishing.
I believe the MXF files you referred to would have been lossy as well. According to the
XDCAM wiki, that MXF option appears to be MPEG HD422 @50mbps. What I used was MPEG HD @35mbps and 720p 60fps in an MP4 container (MXF container optional in Vegas somewhere in advanced codec options tabs I guess).
Advantage of the 50mbps MPEG HD422 format:
MPEG HD422 doubles the chroma-resolution compared to the previous generations of high-definition video XDCAM formats. To accommodate the improved chroma detail, video bitrate has been increased to 50 Mbit/s. This format is used only in XDCAM HD422 products.
