Thanks, Wolfgang. You nailed it. That's the problem. For some reason, my system seems to think that the Blu-ray burner has a CD in it, even though it doesn't. What I think is happening is that Vegas sees the drive as active in another application and removes it from consideration. When I connect a second, external Blu-ray burner, Vegas recognizes it and all is good.
So, the problem is probably a simple Windows issue, and I need to figure out how to reconfigure the drive slightly so this doesn't happen. Changing how autoplay works may fix it, but I'm not sure that's the root of this problem. Any suggestions?
