Originally Posted by
ccotenj
posted this q in the radiance mini thread as well...
anyone using a 3dbee in conjunction with a radiance? if so, you got the bee before or after the radiance?
i'm thinking after will be best, but was wondering if anyone has any feedback?
I posted this in the Lumagen thread, but it might be useful to share it here as well:
During the period that I tested a 3D-Bee, I routed my Blu-ray player to an HDMI switcher. One output of the switcher went direct to the Radiance, and the other went to the 3D-Bee, which was then in turn connected to a different input on the Radiance.
The 3D-Bee will passthrough 2D video from Blu-ray or will convert it to 3D, but will not passthrough real 3D content. If you expect to watch genuine Blu-ray 3D discs, you'll need an option to bypass the 3D-Bee.
If you only have one HD display (with multiple HDMI inputs), instead of using a switcher like I did, you could connect your Blu-ray player to the Radiance, and then have one HDMI output from the Radiance go directly to your TV and the other to the 3D-Bee (which would go to the TV separately). That didn't work for me, because my Radiance is connected to two displays and already uses both HDMI outputs.
Make sense?
If it helps, I have a color-coded visual illustration of my connection map
here.
