Originally Posted by
virtualpaul
Thanks for the reply.
For a 3D projector, which 3D-bee model would you recommend?
I have read your other thread about dual projector system but after reading about the 'straight head' requirement, I have decided to buy an active eye glass 3D projector while waiting for some passive ~realD compatible projectors to come out at reasonable prices. Would you recommend one in the $3k price range (Panasonic PT-AE7000, Epson 6010, ...)?
Because I'm using the dual projector setup, I haven't had enough interest in the single projector 3D solutions to look at the newer ones, so I don't know if I could comment.
What I can say is that since you would be using a single projector, you can use any version of the 3D Bee. The top Pro version is only needed for the dual projector solution.
I would recommend the Trainer version for the extra $100, since it gives you some flexibility to play with different modes. But the default "-" mode is what I use most of the time myself, so either is good.
