@archer16
The 3D-Bee::trainer has two 3D modes. The first mode is 60Hz side-by-side up to 1080p like the 3D-Bee::home. This will work with most 3DTVs and also 3D-ready projectors that accept side-by-side video. The second mode is 720p 120Hz frame-sequential. This is the mode that works with most inexpensive 3D-ready projectors. When you use the frame sequential mode, you need to change the settings on your video sources to only 720p as the 3D-Bee does not scale. If you don't change the setting, you'll be able to get in to the SBS mode, but when you try to change to the frame-sequential mode, it will kick back to 2D/Bypass if the input resolution is not 720p.
@Steve Tack
The 3D-Bee::home is primarily for 3D TVs, however a few people do have side-by-side projectors which the Home model will also work on up to 1080p resolution. The 3D-Bee::trainer works on 3D TVs up to 1080p in its first 3D mode, and works with the more common type of 720p 120Hz frame-sequential 3D-ready projectors in the second 3D mode.
@sddp
ERRATA for the 3D-Bee::home and 3D-Bee::trainer
When in 2D/Bypass mode, the 3D-Bee will bypass 2D video from the input to the output to enable the viewing of video in 2D if desired. It will also bypass 3D video from input to output for some types of 3D sources. While the 3D-Bee is HDMI certified, some types of 3D sources may have different HDMI characteristics and not be able to bypass through the 3D-Bee. In these situations you can:
Connect these directly to another HDMI input on your TV, or
Add an HDMI splitter where one splitter output goes to the 3D-Bee for conversion of 2D to 3D, and the other splitter output goes to another HDMI input on your TV for viewing original 3D from that video source.
Thanks for all the wonderful feedback from everyone!
@Steve Tack
@sddp
