Micca EP600 - Page 16
post #451 of 570
Originally Posted by Tiddles88 View Post
What has PAL/NTSC got to do with anything? Virtually every TV built within the last decade at least supports both. As to quality components - what? This isn't a mobo where you can compare VRM's and capacitors and build quality. Its just a chunk of PCB with the 1186/85 chip on it with some RAM. So what quality? And if you have playback problems post a 2min sample of the file and have someone test it before making blanket statements.
Thats precisely why I was laughing at canton 160 when he said that he uses PAL and thats why his runs "PERFECTLY"
i HAVE A EXTREMELY MODIFIED 900B--you can see it on the forum here--a complete case change as the 900b and micca have very bad cooling--the components in my dune--separate power supply quality circuit boards and capacitors--fan the actually circulate the air which the 900b and micca dont
The new 900c has made a step forward in their form factor and must have leant by their very bad design of the 900b and micca
dont have to go to show you actual footage as its well documented here
I have tried everything to stop the hassles with the 900b and just not happy with it--have tried the micca firmware but that intoduced some other problems
WILL follow the 900c to see if its better
post #452 of 570
Originally Posted by canton160 View Post
do you have a micca ? no ... you have a himedia why you posting here, wrong forum this is micca related, start reading the threat from beginning is explicit that IS NOT ADVISED TO USED DIFFERENT FIRMWARE IN HIMEDIA, anyone open the machines and compared side by side ? a media player is not made only by realtek 1186 or is it ???
why you comparing issues from a himedia that don't have original firmware to a micca ????
do you no if every micca users have same issues ????
chezz...
The 900b is exactlty the same as the micca ep950
its made by the same company[himedia]
the firmwares are interchangeable because it is the same unit--this is now born out by many who have done
Ihave checked side by side before I did the firmware change
I come to the micca forums to see if they have fixed the issues I wanted fixed
Not everyone uses the same hardware setup and that can cause issues
All I want is a player to play fine out of the box---the 900b and micca doesnt
I have been spoilt by my dune but that doesnt play 3D
I do get a laugh at your comments and thanks:rolleyes:
post #453 of 570
Are you able to install Android apps on the EP600, or is that just for the EP950 (and HiMedia HD900) with internal HDD support?
Was just wondering if anyone has thought of (or already has) tried the XBMC Android app on one of these players to see if it would function. I know it would only provide software decoding at the present time, but if the application runs and they can get hardware decoding abilities going that would be great for these devices.
post #454 of 570
You need the XIOS or Android based media players / phone / tablet to do that. I don't believe you can do it with any of the Micca media players. Different hardware / software.
post #455 of 570
That's a shame, was hoping it would make it's way to a cheaper streamer that provided 3D ISO support. Thanks for the heads up though.
post #456 of 570
Don't count Micca out. If Realtek pulls out of the media player market, I believe Micca will have to choose a different chip.
post #457 of 570
Is there any way to see a description of the movies using this device? Kind of like how the AIOS has a split, wall, etc view (if you generate them in ThumbGen).
post #458 of 570
Does the EP600 recognize USB drives that Mac formatted, i.e. HFS+ ?
post #459 of 570
@sdg4vfx
You need to ask to threat owners gusgus and eagle2, they are the experts....err ...i mean micca bashers on service.
One doesnt own a micca and the other might found a issue with macs... Tought.
If you own or future owner of micca dont make nice statments about it, you will be considerer persona non grata, lier or micca employer. Lol
Funny guys, they should write for leno.
post #460 of 570
I have both HFS+ and NTFS drives plugged to a USB hub connected to the Micca. It reads them all with no problems so far. A nice surprise as HFS support is not listed on the player's specs.
post #461 of 570
@sdg4vfx
We just say the truth. I don't like people who provide the wrong information to others by saying that Micca is the best and perfect media player there is. This isn't true. Micca does a lot of things right, but it has bugs, which hasn't been fixed. Furthermore, Jack hasn't been on this forum for a while now, and he was probably the only support anyone could get from a Micca employee.
post #462 of 570
Hey is anybody else having problem with player playing files with dolby digital audio. ?? I don't hear anything, My receiver is connected thru optical audio cable from micca ep600g2. Everything is selected as RAW in player audio setup.If i change SPDIF to LPCM in setup, i hear sound but its not DD.I know my receiver can't decode HD-audio but it can decode DD as far as i think. any ideas?
Also im still unable to make the whole picture fill the entire screen without the blackbars. zoom button was not very helpfull.
post #463 of 570
I don't have this player but a couple things you can try/look at. If you have multiple audio tracks in the video try switching to see if it's using the wrong stream. Not sure what receiver you have but check your receiver setup, i.e my Onkyo requires you to activate the port for a particular source and configure what it outputs such as stereo, DD, etc. (listening mode preset).
As far as black bars, you understand aspect ratio and the reason for the black bars don't you? I assume that's what you're talking about.
post #464 of 570
@sdg4vfx
I "bashed" this player as well (and actually OWNED IT) and don't even get an honorable mention...
post #465 of 570
post #466 of 570
I just bought the Micca EP600 a few weeks ago. Overall, I am quite happy with the unit. However, there are 2 issues with the unit and I just wonder if those of you who own the unit also have:
1) Video and audio out of sync on some movies played from a hard drive, mostly 3D or Blu-ray movies
2) The menu display and subtitles are magnified and can not be made smaller
I only have this problem when the Micca is hooked up to the Devon receiver, and receiver to TV. If the Micca is hooked up directly to the TV, the problem goes away. Thank you so much for sharing.
post #467 of 570
if you read a few posts back or in micca 950 threat , theres issues with devon receivers, micca is not the only one, others players experience the same with devon.
beware the bashers army might tell you otherwise.
regards
post #468 of 570
regards
Oh yes, I have had 21 different media players the past 17 months and only the mica had problems with my Denon 4311, so yes, be very sure to read up on this player...
post #469 of 570
here a link with denon audio drop out issues, its already a feature of denon along with blue rain.
http://www.google.pt/search?hl=pt-PT&output=search&sclient=psy-ab&q=denon+4311+audio+drop+out&btnK=
@norm duong i advice you update to latest devon firmware avaiable.
post #470 of 570
Canton160 is the resident fanboy here on this player. It works 100% and has no issues for him. So, of course, the problem MUST be your cheap piece of crap $2000 receiver because the media player is PERFECT!
The "blue rain" he brings up on the Denon was fixed almost two years ago and has absolutely NOTHING to do with this player not playing nicely with my Denon 4311...
Keep reading and between the various posts you will see that it is an ok player but has issues...
post #471 of 570
+1
post #472 of 570
+ 2
post #473 of 570
did you bother to read ??
expensive products don't have problems ?? do you see how your + $2000 statement is stupid ??....i guess you don't .
its like talking to a rock....jezz.
Edited by canton160 - 7/30/12 at 12:59am
post #474 of 570
Canton 160 you never fail to make me laugh:rolleyes:rolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gifrolleyes.gif
post #475 of 570
you also make me rolleyes..... when you are participating in a threat, and you don't even have a micca player to talk about and share your experience.
but you are not the only one, theres more users that speak by suppositions and theories of other users using the micca.
actually, i would have a shame of participating in a threat, or give advice, or correct others, if i dont actually own the device.
you have a himedia 900b and a dune, what bother you about micca being a good player and working well ? or you just came here to take a laugh, if that is the reason, stay quiet in your corner and enjoy the show, because your opinion about micca is only "smoke".
Edited by canton160 - 7/30/12 at 3:37am
post #476 of 570
I know I might get blasted for this but to be fair from a hardware standpoint for the most part the Himedia 900b=Micca 950=Micca 600 G2.
The differences between them that do exist are mainly output and input based so I can't see where denass is out of line for commenting
in this thread.
Again I am open to correction.
post #477 of 570
Canton,
The reason why I, and many others haven't bought a Micca player is because it doesn't do what is supposed to do. Why should I spend $150.00 on a media player that is not working properly. I already know that the Micca cannot play 3D properly. I already know that Micca can play 2D movies, but I've got two media players that can do that already. Micca knows about the 3D issues, and they are working on the issue, but no one knows when this will get fixed.
Mede8er came out with their own 3D player based on the 1186 chip as well. They are having the same issues as well. So, unless Micca or Mede8er fix these 3D issues, I will not buy one. If you have not noticed, I have been recommending Micca to many people who want to buy a good and inexpensive media player. I think for the money Micca has a lot to offer, and I do hope they get to fix the 3D issues. I also hope their customer support and quality control improves as well because they are getting worse.
post #478 of 570
As others have said the micca and the himedia are the same unit--it seems you cant comprehend this.
I have tried the micca firmware and it works but the 1186 chip seems to be the problem--micca and himedia cant fix the bugs in the chip unless the chip manufacturer helps
I hate the stuttering on some 2d stuff--the new firmware helped but didnt fix it
My dune doesnt exhibit any of the problems of the himedia/micca and plays well with a jukebox I use
these are fundamental things that shouldnt have happened
its a major thing too not playing at the right frame rate and playing at 24hz
To be fair they are cheap players and you get what you pay for
But I admit I laugh alot at you canton--I make a point now not drinking my tea while reading your comments:)
post #479 of 570
QFT. I also have a Denon 4311 and have issues between it and my Micca 950B in relation to DTS-MA and 24p.
Also, canton160, the word is threaD not threaT, THREAD.
Bill
post #480 of 570
Glad to see I'm not the only one that was being annoyed by that, but I thought I was being petty and didn't say anything. biggrin.gif
