Latest HD900 firmware is coming. Please try:
http://dl.himedia-tech.cn/HD900B/HD900_1.0.3.8.tar.gz
New function
1. Support seemless playback on HiTV's site, say Youku,Qiyi,Sohu,Ku6
2. BD Lite Navigation support 3D mode playback
3. deep color default as AUTO。
4. Add timezone setup
5. Add Hebrew support
6. Add Vietnam support
7. Add Poland language
8. Enable Telnet function
9. Add the setup for 3D depth of field.
10. Fix the BT function
11. Fix the bug in youtubeXL
12. Add new function for network diagnostic
13. Add HD900C product supported
Bug Fix
1. Fix the failure of switch 720P to 1080P on some TV set
2. Fix the wrong OSD overlap on DVD Menu
3. Fix the jitter issue on 3D playback 。
4. Fix the srt issue on network share playback。
5. Fix the playback failure on some special content 。
6. Remove the subtitle's comments { }
7. Fix the 3D jitter issue in BD Navigation playback mode
8. Fix the issue about idx+sub
9. Add setup to adjust Left-Right on 3D
10. Fix the BD Navigation on error detection of main movie
11. Fix the bookmark issue 。
12. fix the restart play issue on switch between 3D and 2D。
13. Enhance the wifi research function
14. Remove MP4 type from audio list
15. Clear all DNS address at network re-setup
16. HD900 can't be founded in network share by device name。
17. Fix andriod display issue if there are too many APK install
