AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › Newb ultra budget HTPC build - requesting help
post #1 of 7
I read this article gadgetscholar.com htpc under-250/
budget as close to $200 and maybe up to $300 if there is a very good reason to spend extra.
I want to:
play Movies from DVD and hard drive
play Music
watch netflix
and possibly highlights from NHL.com (silverlight?)
I might like to add a remote control down the road
My tv is an old (420p?) 32" LCD that was just given to me. I have intermediate computer skills. This will be my first experience with Linux. I am an Apple guy and have experience with Windows.
barebones system: Foxconn R10-G3
http://www.newegg.com/Product/Produc...82E16856119018
processor:Intel Celeron E3400 Wolfdale 2.6GHz
http://www.newegg.com/Product/Produc...82E16819116348
Video Card: MSI N8400GS-MD1GD3H/LP GeForce 8400 GS 1GB 64-bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Video Card
http://www.newegg.com/Product/Produc...82E16814127538
HDD: Western Digital Caviar Green WD10EARS 1TB 5400 RPM 64MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Produc...82E16822136490
Bluetooth adapter?
http://www.newegg.com/Product/Produc...82E16833340019
WIFI:
http://www.newegg.com/Product/Produc...82E16833166011
1. What are the chances the bluetooth adapter lets me use an apple wireless keyboard and mighty mouse?
2. Can I use the DDR3 video card?
3. Anything missing or other mistakes?
post #2 of 7
Just a quick "gotcha" -- unless something has changed recently that I don't know about, silverlight doesn't work in linux, so no netflix, etc.
post #3 of 7
thanks, I will have to figure out if I am going to run Windows 7 I guess I have enough drive space to run both.
post #4 of 7
You never heard of Moonlight?
http://mono-framework.com/Moonlight
Edit: Moonlight most likely won't let you watch Netflix on Linux. This is because of DRM.
http://jacksonh.tumblr.com/post/9658...-on-linux-with
I know that it is not because of Linux. I have a Roku box that supposedly runs Linux, and Netflix is available on that.
post #5 of 7
Originally Posted by waterhead View Post
You never heard of Moonlight? ...
Yeah, but it's pretty pointless without DRM because that's the only reason anyone publishes content in Silverlight anyway. Plus, while there's a version 4 beta, the last stable version is 2, and MS is already on 5. So, it's just easier to say that it doesn't work.
post #6 of 7
Couldn't you run Netflix with a Windows VM on Linux? Or would that not perform well enough?
Apparently you can. But IMO a cheap Roku would be a better option, because you don't need a keyboard and mouse. Or any of a number of cheap BR players that can do Netflix, Amazon, Youtube, etc. I always try to avoid use of a browser for a Myth install used on an HDTV.
post #7 of 7
Is there a reason you want a HTPC?
Something like the LG BD690 may fit your needs.
http://www.amazon.com/LG-BD670-Wirel...9339499&sr=1-2
Don't have any experience with these new players but they seem to do most of what people want in a HTPC (except record and playback of TV of course! --- which is actually most of what I do)
  Back to Forum: HTPC - Linux Chat
