Originally Posted by
Metsuke
Regarding the earlier discussion of RAM expansion, it's probably too late but I really wish that Sony had tried a half-step upgrade, call it the PS3X or something.
Maybe they could still drop it out this summer, a month after E3 or so. Imagine this and see what you think:
- They announce Playstation 3X during their E3 keynote, slightly upgraded and remodeled
- SuperCell, 2 PPUs and 12-16 SPUs or so
- Maybe a slight clock bump (although 3.2 GHz is already pretty hot)
- Bit-compatible NVIDIA card that supercedes RSX, ~768 MB of video RAM and improved bandwidth across the board
- 1 GB or so of system RAM
- 4x or 6x Blu-ray
- All current PS3 games are certified and 99% backwards compatibility is engineered in
- $450, available next month! (Crowd oohs and aahs)
Now, to make it commercially viable, you also say:
- Regular PS3 support continues with no change
- No games will be certified for 3X unless they also run at a reasonable level on regular PS3, "reasonable" determined by Sony QA
- Above policy in place for 12 (or maybe 18) months following the release of the 3X (and then devs can target the 3X only)
Desired results:
- Smaller devs without a lot of resources (PSN, etc.) just continue to make PS3 games and no additional cost save maybe the extra hassle of doing QA on the 3X
- Same with bigger devs that just don't care (Activision, etc.)
- Sony 1st/2nd party and other ambitious multi-plat devs release games with full PS3 support & also code their engine to run with better resolution and/or framerate and/or shaders, etc. on the 3X
- Current PS3 games with variable framerate run better with no additional tuning (think GT5)
- The system has equal or better specs than WiiU and crushes it in existing software library, beats MS to the punch to next gen, and requires a fraction of the R&D that a normal new console launch does
Drawbacks:
- Maintaining two console platforms going forward has lots of extra cost for Sony
- MS could over-engineer their next-gen offering and leapfrog the specs by quite a bit as quickly as a year later
