AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Toshiba BDK21
Toshiba BDK21
post #1 of 6
has anyone heard anything about this player???? Costco has it for $69.99 regular price (after doing some research it MAY be Toshiba 2150 rebadged for costco and sams club). haven't seen any of the Toshiba's reviewed on here yet.
post #2 of 6
I bought a Toshiba BDK21 Blu-Ray Disc Player for my daughter's room. It supports access to our home network for connecting to Netflix, Pandora, etc. The unit has an Ethernet port and a USB port.
I went to BestBuy last night and purchased a Belkin USB Wireless Adapter. I set it up on a Windows computer and verified that it worked with the computer. Unfortunately, I can't get it to work on the BDK21.
A quick review of the Toshiba user guide indicates that the unit is only compatible with their USB Wireless Adaptors, WLM-10UB1 or WLM-10NB1.
I expected wireless adapters to be wireless adapters, but I'm concerned Toshiba did something proprietary. Should I just give up with the Belkin adapter and order the Toshiba one?
Thanks for any advice,
-- Robert
post #3 of 6
Doesn't work that way. They are proprietary with all BD players. You don't need to give up. You can use a bridge/gaming adapter.
S~
post #4 of 6
I'm very grateful for your quick reply. Thank you!
-- Robert
post #5 of 6
I have this Blu Ray player is really good, the only bad thing is when you are seeing a movie thru USB in certain time the player stops, so in order to see the movie you have to press play in certain time intervals until you finish the movie, this do not happen seeing a blu ray disc.
Very good player by the price!!
post #6 of 6
-- Robert
Robert;
Do you know how to convert this player to multiregion player?
Regards;
Mr. Vargas
