I searched the forum and found some people discussing the AVR 4810 networking problems. I've got the problem now, my router will assign an IP address over DHCP, but the "Network Info" page sometimes doesn't even know what it is. The IP address is pingable from a computer, but I cannot access the web interface for it. Also, the "Networking Connect" option isn't even openable from the menu. WIFI does not connect either, and because I cannot open "Networking Connection" I cannot even choose the appropriate access point. I've tried resetting the unit a few times and gained nothing out of it. It cannot connect to the server to try to do a firmware update (well, it doesn't fail, it just sits there for hours trying to connect).
Based on this, I assume I'm affected by the networking defect others have described. So, question is, has Denon actually solved the issue? I've found posts online stating that even sending it in for maintenance only fixed it for a few days / weeks. I guess the question is, should I just resign myself to have a faulty unit or have there been actual success stories? Quite annoyed....
