AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Denon Link Cable
Denon Link Cable
post #1 of 2
Where can I find a Denon link cable at a reasonable cost? Or could a simply use an ethernet cable. If that is the case, will the ethernet cable be straight through or crossover?
Thanks All
Al F
post #2 of 2
My original Denon Link cable looks like it is a CAT5E or 6 STP (shielded) straight patch cable. I think that AudioQuest has a Cat5E that some people reported it worked with the DLIII. Mine came with the DVD-2930.
http://www.musicdirect.com/p-228-aud...net-cable.aspx
  Back to Forum: DVD Players (Standard Def)
