AVS › AVS Forum › Display Devices › CRT Projectors › fix a fuzzy Sony 7220 Crt
post #1 of 2
I have a Sony 6' Projection I bought brand new 25 years ago it worked great but when it stoped dead I took it to be repaired and was told it needed a power transformer board ( not true I discoverd) after it's return it was never as sharp as before ! I'm sure he screwed something up somehow.
It does get a little better after an hour or so but not as great as it was.
Does anybody have copies of the service manual so I can tell what does what under the hood ?
Thanks for any help with this.....
post #2 of 2
On those old models you have to adjust the focus block and the G2 after the transformer is replaced
The tech was just lazy
Greg
www.eisemann-theater.com
  Back to Forum: CRT Projectors
