AVS › AVS Forum › Audio › DIY Speakers and Subs › TD12M, DE250, SEOS 12...Active Design
TD12M, DE250, SEOS 12...Active Design - Page 2
post #31 of 48
or use the "text to columns" command in excel and then choose "delimited" and check "space"
post #32 of 48
Ah, thanks again. See all these things we learn. Hopefully someone can learn from this:
Ok, here we go.
Start up PCD and follow these instructions.
PS. I'm trying to use the avsforum image management system. Not sure I got it right.
post #33 of 48
Ah shoot. I can't attached the .csp and .ftr.
If you want them, pm me. Or you can just follow the steps and create your own.
post #34 of 48
Those look terrible. Photobucket is just plain easier.
These might not last forever though.
post #35 of 48
Originally Posted by coctostan View Post
Give some more details like room dims and setup. Maybe we can make something work. I highly recommend using a toe-in where the axes cross in front of the primary listeners. This can be made to less box width at the expense of more depth.
Visual serving suggestion for smokarz.
post #36 of 48
You should be able to put them in a ZIP file and upload them to an AVS post.
A9X, that is the look I'm thinking. It kills two birds with one stone. You get the toe-in you need and reduced width. It can be built to fit the dimensions of your room.
post #37 of 48
that looks great.
but it seems a bit difficult to build, for someone who is very deficient in woodworking skills.
post #38 of 48
How is this coming? Do my instructions make any sense
post #39 of 48
sorry tux, haven't even got a chance to try it out.
hopefully sometimes soon.
post #40 of 48
Smokarz,
I could have missed it in an earlier post but were you planning on running these as mains (front three)? If so, what amplifiers were you planning on using?
post #41 of 48
Originally Posted by orcarola25 View Post
Smokarz,
i am running only 2 fronts. my mains are roughly 8ft apart, so no need for a center really. imaging is pretty dead centered with them toe-in.
i have a seven channel amps 125wpc, Emotiva UPA-7.
might pick up a 2-channel amp (around 50wpc) to run the DE250s.
post #42 of 48
Everyone is still waiting on the GB stuff eh!
post #43 of 48
pretty much.
honestly, i won't be doing much until may/june when the parts arrive.
waiting on the AE drivers, and Erich is still working on putting the DE250 and SEOS stuff together.
post #44 of 48
Things are coming together. I have received my parts from Erich today and AE has the parts.
Edited by bg40403 - 6/21/12 at 9:44am
post #45 of 48
Yes. Got the stuff from Erich.
Waiting on the AE drivers.
Almost forgot this pet project. Was busing working on screen/pj.
post #46 of 48
I'm looking forward to seeing what you guys come up with for these big designs biggrin.gif
Are you still going active Smokarz? Or have you decided to just go with a design.
post #47 of 48
i am hoping one of the designers can cook up something.
if not, then i'll have to get a minidsp and start taking lessons. biggrin.gif
post #48 of 48
I'm in the fray, as well. FYI, rumor has it that PE will begin carrying mini DSP in the product line. I have solicited a start date with no results. Wait and see.
