Originally Posted by
ratherb1
whaaaaaaaat ...................... ive been playing for about 4.5 days and im on my 5th prestige it does not take me 8-12 hrs of playing time ....it takes me about a day or more
im usually playing tdm or hardcore kc or hardcore tdm i dont know if this is my problem
I think it's the modes you play. It defiantly shouldn't take a full day of play time to prestige. Hasn't been that high in any cod.
Try playing other modes. I hit 10th prestige right on 5 days played. It was about 4 days and 23 hours when I did it. About 10 hours later I was level 80.
I also had a ton of double xp using those mountain dew and Doritos codes. Had the full 24 hour limit. Plus the tokens I had from prestiging in all the games before.
I know it took me a little under 8 hours to do my very 1st prestige. I made sure I checked the exact second it allowed me to.
I also used a token to unlock stinger and assassin. You get crazy points shooting down air support. Being off the grid makes it even easier.
Blind eye pro is awesome because you don't need a stinger. Just shoot at it and it always dies. Unless its an osprey gunner.
