Originally Posted by Vyrolan
Monoprice has a newer revision of that same product (new pid 7974). The newer one is getting better reviews and a few even specifically comment that it is superior in reliability than pid 5577.
In the specific use case of HDMI sources to powered Zone 2, it'd almost be nice just to have it as a convertor...even if you don't use any of the other 3 inputs. =p
They also have a 4x2 matrix where the first output has simultaneous parallel analog output via RCA...again a decent solution for getting HDMI sources to powered Zone 2.
The rub though with that 1st switch you suggest (7974) is it doesn't have an analog output so you have to spend even more money on an optical--> analog converter. Also 5557 is not replaced by 7974, rather 7974 is simply a newer and similar model as they are different.
I'd love to pony up for the 3313 and get even bigger amps, HD radio, and Zone 2 HDMI, but I just don't see it for the huge price jump.
, so I guess the 1713 is the receiver for me as I also want AirPlay and Internet radio (both a must).
