No confusion.AVS › AVS Forum › Audio › Receivers, Amps, and Processors › When do the 2013 Denon's come out? Any new features we should expect?
Featured Stories
Related Forum Threads
- The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ Last post on Today at 8:22 am in Receivers, Amps, and Processors
- Marantz NR1603 vs Denon AVR-1713/AVR-1613 for stereo use. Last post on 2/18/13 at 8:39am in Receivers, Amps, and Processors
- Denon 1613 or 1713 (Help) Last post on 2/14/13 at 4:07am in Receivers, Amps, and Processors
- Will the AVR-1713 and the AVR-1913 sound much different? Last post on 2/1/13 at 3:49pm in Receivers, Amps, and Processors
- Pioneer Elite VSX-51 for $299.99 or Wait for Denon AVR-1913 sub $300? Last post on 12/7/12 at 8:07pm in Receivers, Amps, and Processors
Related Articles
Denon 2011 and 2012 AVR FAQ, Setup, and Troubleshooting Guide
Edited on 9/13/12
Related Reviews
When do the 2013 Denon's come out? Any new features we should expect? - Page 50
post #1471 of 1844
7/15/12 at 10:50pm
Gear mentioned in this thread:
post #1472 of 1844
7/16/12 at 6:45am
- mchrisbrown
- Trader Feedback: 0
- offline
- 83 Posts. Joined 8/2005
- Select All Posts By This User
Originally Posted by batpig
(note that the info below is inferred operation based upon what we know so far and how it has worked on past models, e.g. 4810ci with a digital "Zone 4)
It's really pretty simple:
3313ci = three zones
4520ci = four zones
on the 3313ci, the HDMI zone output is "stuck" with the same source as Zone 2. On the 4520, the HDMI zone output is "detached" from Zone 2 or 3 in terms of what source is playing. But nothing is stopping you from setting Zone 2 and Zone 4 to the same source if you want to "coordinate" the two.
the thing is, it's not like the 4520 lacks something the 3313 has, it has the extra capability of being able to do the HDMI zone matrix thing without gobbling up one of the zones.
Honestly, the analog zone output and the HDMI matrix switch aren't really meant to be coordinated anyway, you might experience sync issues plus of course all the extra cables. I would recommend you instead simply feed the outside TV with the HDMI cable, and then if you want to pipe audio to speakers you can feed them from the audio output of the TV (e.g. adding a small amp).
4520ci = four zones
Thanks, got it. I think I've FINALLY found one receiver that will do everything I want. I'm not aware of anything else that does all of the below:
HDMI matrix switch
Audessey XT32
9 amps (independent zone 2 and 3 through speaker posts with 5.1 in main zone)
Digital audio sources (optical but not HDMI) to zones 2 an 3 through the speaker posts - actually do we know this for sure - the 4311 does so I'm thinking it would but...
Remote control via android phone
I do wish the 4520 cost a little less but if I can finally find one AVR that meets all of my goals I'll just bite the bullet on cost and be done with it!
post #1473 of 1844
7/16/12 at 7:35am
- jdsmoothie
- AVS Addicted Member
- online
- 34,402 Posts. Joined 9/2007
AFAIK, not confirmed one way or the other. The 3311CI and 3312CI are also capable of this feature, however, it was removed on the 3313CI with the addition of the Zone 2 HDMI output.
post #1474 of 1844
7/17/12 at 9:33am
- mchrisbrown
- offline
JD and BatPig, thanks for the input. I REALLY hope that the 4520 will be able to output digital audio to zones 2 and 3 as I've been a Denon fan for years and would love to stay with them (currently own a 3805 and very happy with it). It's just that I spend a lot of time on my back deck (zone 2 with audio and video) and front deck (zone 3 audio only). Most sources are HDMI now and I really want to be able to listen to all sources in all zones. I could even deal with running one extra cable to make this work but in some cases I would have to run the HDMI cable for video then the optical out to a cable to a converter box to a cable to the receiver for each source that doesn't have analog outputs but does have have optical. For some streaming boxes there's not even an optical out having HDMI and HDMI only (ROKU2 XS being an example). My dream scenario is that the 4520 would be able to decode HDMI audio and I could use one cable for every source and still be able to listen to all sources in all zones. I believe that I read in one of these threads that nobody does this but I' think that may be changing. It looks like Onkyo will have this feature as described here: http://www.us.onkyo.com/press_releases.cfm?id=267 and the text below.
HDMI connectivity has also been enhanced by adding Zone2 HDMI connectivity that removes the need for a secondary analog connection in order to access audio in a second zone. Powered audio is available in up to three zones simultaneously—with multi-zone playback and setting controls managed by remote app.
If the 4520 has any type of digital output (hdmi or optical) for zones 2 and 3 I'll probably stay with Denon. If it's going to be analog only I'm thinking of going with the Onkyo to make my life easier. Is there any reason I shouldn't consider the new Onkyos since they have the feature set I am looking for?
Edit: I know I can accomplish some of my goals with converter boxes, converter cables, or additional amps but I just want to plug everything into one box and not have the extra cabling.
post #1475 of 1844
7/17/12 at 10:34am
- cybrsage
- Rebel w/o Applesauce
- online
- 7,010 Posts. Joined 5/2007
post #1476 of 1844
7/17/12 at 11:04am
- jdsmoothie
- online
The bolded portion does not imply "digital" to all 3 zones, rather simply that there is "powered" audio to each Zone (analog or otherwise).
post #1477 of 1844
7/17/12 at 11:20am
- mchrisbrown
- offline
So based on your interpretation you feel HDMI audio can go to zone 2 but not zone 3? How about optical audio on the Onkyos? Can that be sent to all zones?
post #1478 of 1844
7/17/12 at 11:30am
- jdsmoothie
- online
Correct (based on my interpretation). The Onkyo will likely offer the same feature as the 3313CI and 4520CI in that HDMI audio/video can go to a 2nd zone only. As Onkyo never had the capability to pass PCM 2.0 over optical/digital coax to Zone 2, it's unlikely (but still possible) that this feature would be included in the 1010, especially now that Denon has removed the feature from the 3313CI.
post #1479 of 1844
7/17/12 at 12:12pm
- ccotenj
- Trader Feedback: +30
- offline
- 21,915 Posts. Joined 3/2005
to add on....
a hdmi sink would still be required in zone 2.... it is highly unlikely that it will process the hdmi input, convert it to analog, and then send it to zone 2...
the matrix switch sits "before" the input is processed by the avr... when they say "zone 2 hdmi connectivity", that's exactly what they mean... an hdmi out to a subzone...
post #1480 of 1844
7/17/12 at 12:42pm
- mchrisbrown
- offline
post #1481 of 1844
7/17/12 at 12:47pm
- batpig
- terrorist and rioter
- offline
- 21,146 Posts. Joined 2/2007
post #1482 of 1844
7/17/12 at 12:55pm
- ccotenj
- offline
Thanks guys. I was thinking and hoping I'd be able to just plug in an HDMI cable from a source and pump sound to any zone. Whoever figures this out will make a lot of people happy. If this is just another matrix switch like the Denon 3311 them I'm back to leaning Denon's way again.
it's really not a matter of "figuring it out"... it would be easy (relatively speaking) to implement.... the problem is that it would add a significant cost to the bill of materials for a feature that very few buyers would actually use.... you would require two completely independent hdmi paths in the avr, not to mention double the processing power....
post #1483 of 1844
7/25/12 at 11:01am
- IwantmyTHX
- Got it!
- offline
- 408 Posts. Joined 7/2003
post #1484 of 1844
7/25/12 at 11:35am
- jdsmoothie
- online
post #1485 of 1844
7/25/12 at 12:12pm
I believe that the upcoming Emotiva XMC-1 will take the main zone HDMI audio and downsample it to zone 1 & zone 2 analog outputs.
post #1486 of 1844
7/25/12 at 9:36pm
- 67 - 427
- offline
- 186 Posts. Joined 1/2008
post #1487 of 1844
7/26/12 at 3:15am
post #1488 of 1844
7/26/12 at 3:17am
- jdsmoothie
- online
post #1489 of 1844
7/27/12 at 5:42am
- Diagrafeas
- offline
- 6 Posts. Joined 5/2012
post #1490 of 1844
7/27/12 at 5:53am
- ccotenj
- offline
post #1491 of 1844
7/30/12 at 9:53am
Is it reasonable to conclude that the 4520 won't be able to pass through a 4K signal, only upscale a lower resolution as the new onkyo 3010/5010? I know 4K source material /playback/pj/monitors won't be available for a couple years at least, but I don't plan on upgrading the avr for quite a time longer and dealing with a dual hdmi output player to my pj would be a PIA.
post #1492 of 1844
7/30/12 at 10:26am
- batpig
- offline
post #1493 of 1844
7/30/12 at 10:39am
That may be the deciding point for me for the Denon 4520 over the Onkyo 3010. I know this is premature but I'm following closely the new Red laser 4K pj expected to be released by end of year. The pass through function would certainly eliminate the need for dual hdmi output, if the first 4K players even have them.
post #1494 of 1844
7/30/12 at 4:09pm
post #1495 of 1844
7/30/12 at 4:54pm
- batpig
- offline
post #1496 of 1844
7/31/12 at 11:37am
- SoundofMind
- (IMHO)
- offline
- 7,226 Posts. Joined 9/2008
post #1497 of 1844
7/31/12 at 4:06pm
- cybrsage
- online
post #1498 of 1844
7/31/12 at 5:03pm
- mchrisbrown
- offline
post #1499 of 1844
8/1/12 at 4:07am
- jdsmoothie
- online
post #1500 of 1844
8/1/12 at 6:00am
- When do the 2013 Denon's come out? Any new features we should expect?
Currently, there are 1762 Active Users
(387 Members and 1375 Guests)
Recent Discussions
- › budget speaker build 8 seconds ago
- › HELP! Is it my Pre-Pro or is it Cablevision? 17 seconds ago
- › Official Ceton Echo Extender Info Thread 23 seconds ago
- › Official Epson Problem Thread 51 seconds ago
- › AVS Can't-Wait Special—"Mastered in 4K" Blu-Ray Releases 1 minute ago
- › TD15M - SEOS12 - BMS4550 / theater progress / Dual TD6M - SEOS12 -... 1 minute ago
- › Call of Duty: Black Ops 2 1 minute ago
- › 12v trigger / auto on 2 minutes ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 2 minutes ago
- › Official LG 47LM8600/55LM8600 Owners Thread 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
