AVS › AVS Forum › Audio › Receivers, Amps, and Processors › When do the 2013 Denon's come out? Any new features we should expect?
When do the 2013 Denon's come out? Any new features we should expect? - Page 17
post #481 of 1844
Originally Posted by Venomous View Post
I don't agree here. You cant take an original image and compress it without some degradation to the original image. That's impossible to do... You can get it close, but to have an exact duplicate with compression is impossible.
When it comes to video, it's the same thing. Compression does introduce image quality loss. At what level is the the quality loss acceptable, is what sets the standard.
That's absolutely not true from a technical perspective. ZIP files are a great example of lossless compression, as is PNG for images.
For video here is a list of lossless video codecs: https://en.wikipedia.org/wiki/List_o...ss_compression
It is completely technically possible to compress without loss, and this is done all the time.
post #482 of 1844
Looks like they don't have programmable remotes anymore.
post #483 of 1844
Denon programmable remotes are currently only found on the 43XX and higher models (never were offered with 33XX models or lower).
post #484 of 1844
Originally Posted by skro View Post
Are you saying hdmi overlay (volume,etc displayed on screen) starts at the 1613 now?
Yes. 2D GUI overlay on the 1513, and 2D/3D GUI overlay on 1613 and higher (formerly only on 2312CI and 3312CI).
post #485 of 1844
Current information learned so far from various sources (some features are listed in notes section) ...
1513 (MSRP $249.99) ----> 5.1, 75W, 4/1 HDMI, AM/FM, GUI, HDMI Standby pass through, 3.5mm jack, No ARC, No Audyssey, No USB, (April)
1613 (MSRP $399.99) ----> 5.1, 75W, 5/1 HDMI, FM only, MultEQ (April)
1713 (MSRP $449.99) ----> 5.1, 80W, 6/1 HDMI, MultEQ XT, Zone 2 (preouts only) (May)
1913 (MSRP $579.99) ----> 7.1, 90W, 6/1 HDMI, MultEQ, Adv GUI, Zone 2 (Amp Assign), Comp video IN (1), Analog-->HDMI, 1080p/24hz upscaling, PLIIz (April)
2113CI (MSRP $ ) --> 7.1, 90W, 6/1 HDMI, 4k upscaling, MultEQ XT, (May)
2313CI (MSRP $ ) --> 7.2, 105W, 7/2 HDMI, 4k upscaling, MultEQ XT, DSX (June)
3313CI (MSRP $ ) --> 7.2, 125W, 7/3 HDMI, 4k upscaling, Denon Link HD, Aluminum faceplate (June)
4520CI (MSRP $2500?) --> Audyssey LFC(?), DTS Neo:X (?), ???? (Sep)
NOTES:
* Front HDMI (all models)
* Networking/Airplay (Zone 2 independent from main zone)/SiriusXM/Flickr, Pandora (1613 and higher)
* Spotify (1913 and higher via firmware upgrade later this summer)
* GUI (1513, 1613, 1713); Advanced GUI (1913 and higher)
* "Auto Standby" feature: [2hrs, 4hrs, 8hrs, Off] (1513 only), [30min, 60min, Off] (1613 and higher)
* "Dialogue Level" (enhance center channel dialog), Front USB, GUI overlay on 3D video, HDMI Control (1613 and higher)
* Web Control w/SAVE/LOAD of config file/Audyssey (1713 and higher)
* Dynamic Volume renamed from (Day, Evening, Midnight) to (Light, Medium, Heavy)(1613 and higher)
* Audyssey "Manual EQ" relabeled "Graphic EQ" (1913 and higher)
* Audyssey mic ACM1HB replaces DM-A409 (1613 and higher); cosmetic changes made only, interchangeable with DM-A409
* No mention of firmware update via USB in Owner manuals(?)
* iPad connection to USB (1713)
* Larger font size on front panel display
* New Denon Remote App Ver 3.0 with XX13 model unique features (Frequency Direct FM Tuning, Fast Internet Radio Browsing,,Volume Limit Setting)
Features not carried forward from XX12 model:
* Rhapsody and Napster (all networking models)
* Ipod docking station jack (S-Video)
* Assignment of HDMI inputs
* AM radio (1613 and higher)
* Component IN/Out (1713)
* Number of analog audio inputs reduced
* Reduction of 2" of depth in unit dimension
* Preouts: 1513 (Surr Back), 1613 (Surr Back/Front HT)
* Custom 2CH Direct/Stereo settings (1713)
* Party Mode (multiple Denon AVRs in house)
* Denon remote no longer preprogrammed with other device codes
post #486 of 1844
Those would be I assume the learning remotes. My 1712 in the menu gives you preset codes you can set to control various tvs, blu ray players or cable boxes. I use my remote to control my Denon DBP-1610 and would also my tv but being an insignia it uses some weird code that it doesn't have.
post #487 of 1844
Which is why a universal remote (eg. Harmony) is recommended to replace the Denon and all other remotes (big WAF points as well).
post #488 of 1844
Unlike others I like that fact that the back of the new units are less complicated and have fewer inputs. Everything that I plug in is HDMI today and I hate HDMI. The cables don't seat well and to me seem silly. The back of the unit should have speaker posts and a single ethernet cable. Not sure why the industry is taking so long to get there.
post #489 of 1844
So... for the 1713 vs 2112CI .. all I see as different is a few plugs and the powered rear surround.
Has the software changed in any significant way? Processors?
post #490 of 1844
Lengthy preview of the 1713 by Area DVD: http://www.areadvd.de/hardware/2012/denon_avr1713.shtml
German, so you might want to use google translate if you'd like to read it in Korean.
post #491 of 1844
you are going to be waiting a very long time...
post #492 of 1844
http://www.amazon.com/Denon-AVR-1913.../dp/B007R8U5R6
It really takes alot of restraint to not buy this but I will let someone else be first
post #493 of 1844
2113CI (MSRP $ ) --> 7.1, 6/1 HDMI, MultEQ XT, (May)
2313CI (MSRP $ ) --> 7.2, 6/2 HDMI, MultEQ XT, DSX (June)
3313CI (MSRP $ ) --> Picks up a 3rd HDMI Out and Denon Link HD (June)
NOTES:
* Spotify (1913 and higher, although no mention on 1913 webpage or in Owner's manual)?
* 4K video upscaling (2113CI, 2213CI, 3313CI)
Features removed from XX12 model:
* 2" of depth in unit dimension
* Party mode
Sounds like denon is following onkyos lead, denon is dropping some of its best menu options like "Custom 2CH Direct/Stereo settings"
post #494 of 1844
So how do I connect my HTPC to it? Do I need to install another NIC? Currently it doesn't output HD video and HD audio through ethernet, it does it through HDMI. I do agree that HDMI connectors are a bit weak, though.
post #495 of 1844
Looks like the new 1913 is losing alot of weight, like 25% at only 20.1 pounds. That can't be good for amp output. The 1909 was over 25 lbs !
post #496 of 1844
Based on posted spec pages, there appears to be no change in the processor, DAC, or ADC on the 1513-1913 as compared to the models they are replacing.
post #497 of 1844
Just connect it via HDMI which is how all current AVRs work.
post #498 of 1844
I wonder if the xx12/xx13 models use the SHARC Hammerhead 21487 DSP chip?
post #499 of 1844
Yup. 1612/1613 and higher models.
post #500 of 1844
Here it is translated ...
http://translate.google.com/translat...26prmd%3Dimvns
The review compares the 1713 to the 1612 because there was no 1712 distributed over in Europe (one of the reasons why the Europe 1912 has MultEQ XT). It does however, mention the firmware update via USB as well as the capability to connect an iPad to the USB jack (something the XX12 models nor the 1613 or 1913 is capable of doing per their respective Owner's manual).
post #501 of 1844
So, I've been waiting for this announcement to pull the trigger on upgrading my receiver. The 1912 was my bare minimum (Airplay + 2 powered zones). I was considering the 2112CI for the better menu system, and I was actually seriously considering ponying up for a 3312CI, just for the front HDMI, using the extra power, HD radio, and myriad extra inputs (should I ever need them) as extra justification.
I really don't want to wait any longer. I'm not very clear on the differences between the 2112CI and the 1913. Can someone clarify, and/or offer any insights that seem relevant?
EDIT: Denon comparison page for 1913, 2112, 2312, 3312
Looking at the above, I see the following differences betwee the 2112 and the 1913:
* 1913 is smaller and slightly lighter (I don't care)
* 1913 adds SiriusXM, missing Napster and Rhapsody streaming (I don't care)
* 1913 moves one of the six HDMI inputs to the front (I like)
* 1913 doesn't work with Denon's iPod dock, but can plug one in via USB on the front panel (I don't care)
* 1913 has lower analog-to-digital conversion rate, 96kHz vs 192 (I'd never notice)
* 1913 doesn't have independent power supplies (I don't think I care, but high-end characteristics like that appeal to my inner nerd)
* 1913 has MultEq, 2112 has MultEq XT (I don't know what the difference is, but I know XT is "better")
* 1913 has 1080p video scaling; 2112 doesn't appear to do any scaling (I think I would prefer to have scaling)
* 1913 doesn't have "Party Mode Plus" (I don't know what that is)
* 1913 has the on-screen first-time setup guide (sounds nice, but whatever)
The comparison chart seems to indicate that the 1913 doesn't come with a pre-programmed remote. I'm not sure what to make of that. Anyone know?
I know Denon's comparison pages leave things off and/or mislead -- for example, nowhere in the chart does it say that the 3312 has HD Radio, but the 3312 product page does. What else is missing? I might care! :/
Street price for both the 1913 and the 2112 are about the same, so that's a wash. Can anyone fill me in on why I should care about having MultEQ XT over regular MultEQ, or Party Mode Plus? I'm guessing that I won't find those very compelling, and will end up getting a 1913.
Then again, the 3312's third zone, video to the second zone, and the nearly 40% increase in amplifier power are calling to me. It's quite a bit more money, but I can afford it. Then again, the 3313 will almost certainly have all that and a bag of chips, so I'd really have a hard time pulling the trigger on one now.
I'M SO TORN! Somebody help me decide.
EDIT 2: I googled Party Mode Plus. It sounds cool, but I don't think I'd miss it. I also googled MultEQ XT, but I'm still not clear on what it adds over regular MultEQ or why I should care.
post #502 of 1844
1913 -- adv GUI, powered Zone 2 only, Audssey MultEQ, Front USB, 6 HDMI (1-Front), Airplay (independently plays to Zone 2), 2 yr warranty
2212CI - adv GUI, powered & preout Zone 2, Audyssey MultEQ XT, Front USB, 6 HDMI (all on back), Airplay (must also be selected in main zone to play in Zone 2), 3 year warranty,
post #503 of 1844
Denon USA A/V webpage now has the 1513, 1613, 1713, 1913 showing today.
Denon home page has a link to same URL saying "Introducing our 2012 AV Receiver Lineup".
Nothing concerning CI series.
post #504 of 1844
1913 -- adv GUI, powered Zone 2 only, Audssey MultEQ, Front USB, 6 HDMI (1-Front), 2 yr warranty
2212CI - adv GUI, powered & preout Zone 2, Audyssey MultEQ XT, Front USB, 6 HDMI (all on back), 3 year warranty,
What's the difference between the two different MultEQs? I know that XT has 8 measurement positions vs 6, and higher "filter resolution," whatever that is, but I don't know what that means in terms of the effect it'll have on my listening experience. Should I care? This is for a 5.1 system in my living room, used primarily for watching TV and blu-ray movies.
post #505 of 1844
http://www.audyssey.com/audio-technology/multeq
post #506 of 1844
Wow there barely any inputs and output, but lots of hdmi. I must be old school, these new avrs are made for children.
post #507 of 1844
last time i checked, hdmi was "input and output"... also, last time i checked, this has nothing to do with being a child...
do you have anything useful to add to the topic? or are you just pulling your normal routine here?
post #508 of 1844
If you were to compare the two versions, you would likely notice some difference in better audio fidelity from the 2112CI (XT); however, if you're not familiar with Audyssey at all, the 1913 will serve you just as well.
post #509 of 1844
He has never had anything useful to add to any topic so I don't see why he would start now.
I'm just waiting on him to tell us how much better video quality his betamax has than blu-ray.
post #510 of 1844
Sort of wondering if the 3313ci will follow suit and lose some legacy inputs over the 3312ci? If so, what goodies will come in exchange?
