Hi,
I am getting ready to run the Audyssey on my new Denon AVR-1912. I have BIC-PL 200 as the sub and Polk 85I as the front, center and the surrounds. I would like to know what should be the settings on the sub should be when I run the audyssey ? I am not sure what direct mode is. this is what I see in the DENON 1912 manual.
** When using a subwoofer with a direct mode
Set the direct mode to On and disable the volume adjustment
and crossover frequency setting.
** When using a subwoofer without a direct mode
Make the following settings:
Volume : 12 o'clock position
Crossover frequency : Maximum/Highest Frequency
Low pass filter : Off
Standby mode : Off
Please advice.
Standby mode : Off
Please advice.
