AVS › AVS Forum › Display Devices › CRT Projectors › CRT Projection and 72/75Hz
post #1 of 3
Hello guys,
how many people are using 72/75 Hz on their CRT Projection systems?
what experiences do you guys have with the different HDMI solutions
out there? (Moome, HD Fury , ...)
ad any problems with syncing to the higher bandwidths?
I do have a friend that just got the latest HDMI card for a Barco 1209s
and he's got a lot of problems with it concerning 72/75 Hz.
any insights appreciated
Michael
post #2 of 3
I don't know if this is relevant or not, but I have a NEC XG-750 (75 KHz max. scanrate). I have issues related to sync (banding) on straight 1080p60 from HDfury2, but I discovered that if I run it through my video processor to combine the horizontal and vertical syncs to composite sync, the problems go away and it looks perfectly fine.
Running 1600x1200 @ 60 Hz from a PC's VGA output did not cause the same issue and I was able to use the separate sync just fine that way.
post #3 of 3
Our Barco modifications really improve 3d response according to our customers.
The old 800 MHZ opamps used in Barco Cine9 / 909 is replaced with a much more modern faster 2.4 GHZ chip in the video chain that reduces the ghost effect.
Greg
www.eisemann-theater.com
  Back to Forum: CRT Projectors
