Hello,
So i currently have 3 klipsch sub-12's that i got for a steal from bestbuy/kijiji
but i have ye old upgrade bug. Im thinking of selling all three klipsch and buying a single pc-13, but im skeptical. Firstly, cost. I could probably sell the 12's for $900 if im lucky, leaving me with another $900 to spend on the pc-13. Secondly, my room (12/28/8) seems to have lots of dead spots, this might be partially because the rear firing ports are a mere 6 inches from the walls, but its likely from poor room acoustics. Having 3 subs really helped this, so im concerned having only one sub might reveal the dead spots again.
So my question is, is it worth it to upgrade to the pc-13? I realise it goes much lower, and probably sounds much better than the entry level klipsch. I wouldnt expect the single sub to be louder than the triple klipsch's either? In the future i would plan to get a second svs, but it would take a while to muster up the funds for a second haha.
Any advice is appreciated guys.
Oh btw, i have a klipsch f-30 system if that helps.
