So my current built in card supports DVI and VGA, i've been using VGA then got wide screen monitors, used one on DVI and just cant even look at the one on VGA anymore becuz after the nice clean digital picture that analoge image hurts my eyes [i'm spoiled now]. So I need a card with HDMI and DVI so i can have 2 monitors running with the digital picture. Now the computer isnt very fast to begin with [its an older Dell Dimension 8400] but its PCI-E x16. I had a few cards in mind and I was wondering if anyone could tell me which would be better in the case of mostly being used for video viewing/photoshop editing, with some light gaming, most like counter-strike or newer games maybe but obviously at lower resolutions [as my choices are on the inexpensive side]. I'm just not sure if i should go bigger memory or faster memory....
Gigabtye is 1GB size, but DDR3
http://www.newegg.com/Product/Produc...82E16814125392
Sapphire is 513mb size, but DDR5
http://www.newegg.com/Product/Produc...-947-_-Product
