I’m setting up an outdoor speaker system using two pairs of NEAR A6 speakers (brochure: http://www.bogen.com/products/pdfs/nearpdfs/A6s.pdf – manual: http://www.bogen.com/products/pdfs/nearpdfs/A2m.pdf) connected to my SONOS system. I was planning on mounting a pair of A6s on the front porch and a pair of A6s on the back porch. I’m using a SONOS Zoneplayer 120 to power them (http://www.sonos.com/shop/products/connectamp).
My question is whether I can use a single Zoneplayer 120 to power both pairs of speakers. Or do I really need two Zoneplayer 120s?
I was planning on running wires from the Zoneplayer 120 to the front set of speakers and then running speaker wire from the front set of speakers to the back set of speakers (using the poles provided for on the back of the A6s). The area I’m trying to cover is relatively small (on the front and back porch only) so I don’t need a ton of volume from either set of speakers. What do you guys think?
Thanks a bunch for your advice!
