AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › The Official Acer H9500BD Thread
Featured Stories
Topics Discussed
Related Forum Threads
- New Optoma HD33 HD3300 1080p 3D Projector Review Last post on Today at 6:54 am in Digital Projectors - Under $3,000 USD MSRP
- Best 3D projector under $2k? Last post on 8/23/12 at 9:19am in 3D Displays
- LG PA70G LED 1280x800 700 Lumens. Last post on Yesterday at 6:24 pm in Digital Projectors - Under $3,000 USD MSRP
- severe Green tint in 3D mode Last post on 9/4/12 at 7:23am in Digital Projectors - Under $3,000 USD MSRP
- My Sharpvision DT-400 has finally died... Last post on 8/12/12 at 7:20pm in Digital Projectors - Under $3,000 USD MSRP
Related Articles
Projectors 101: AVS’ Favorites
Edited on 10/5/12
- Fall's Most Anticipated Blu-Ray Releases
Edited on 9/17/12- Innovative and Interactive LCD Projectors for Large Rooms
Edited on 9/11/12Related Reviews
Gear mentioned in this thread:
post #2 of 466210/27/11 at 5:39pm- ack_bk
- Trader Feedback: +1
- offline
- 8,520 Posts. Joined 1/2007
- Select All Posts By This User
post #3 of 466210/27/11 at 5:52pm- conradjohnsonfan
- Trader Feedback: 0
- offline
- 272 Posts. Joined 9/2007
post #5 of 466210/27/11 at 7:49pmpost #6 of 466210/27/11 at 8:45pmpost #7 of 466210/27/11 at 8:51pm- ack_bk
- offline
post #8 of 466210/27/11 at 9:35pmI have read about this pj and I think its not dual dvi I see from the back picks it does have a d dvi plug I am hoping the extra pins are being used. Post 3d gaming results, more important than the 5 blurays everyone buys 2k pj on this forum for. Awesome news maybe I can finally get a gaming pj. Please let us know what gpu your using and driver verisons.I have a dual link cable on route...so I will test that out, though from reading some german and french forums it doesn't look promising.
First impressions:
Lens Shift: This is very limited amount of lens shift compared to my Epson 8500UB, but it is enough to be useful. You can move the projector anywhere from the very bottom of the screen to several feet below it depending on your throw distance. The same goes for the top. There is also a decent amount of horz. shift for those that need that.
In my room this enough that I could put the unit on a low coffee table or a high shelf if I didn't want to ceiling mount it.
HDMI handshaking: The projector auto detected a 3d blueray from my PS3 without incident. However any time the resolution or input format changes..the projector takes a little longer to sync back up then I would like.
3D Picture: I didn't spend much time with the 2d so I'll offer my 3d impressions. The projector appeared bright in 3d, though you couldn't change the image mode (standard, cinema, etc) in 3d. Not quite as bright as the H5360 but pretty close.
I currently have a 92" BD II screen, but I still think I want to move to a slightly bigger higher gain screen to get the most out of 3d.
More thoughts tonight.post #10 of 466210/28/11 at 6:13amHi !
Since the H9500BD is the only sub-X0,000$ 3D FullHD projector with a "dual link DVI" connector, we'd REALLY like to know if that projector CAN handle 1080p at 120hz.
3D 1080p at 60hz per eye would be great news for gamers (other consumer-class FullHD 3D projectors only come with an HDMI 1.4 connector which limit input to 1080p at 24hz, so that's only a "not enough" 24fps for 3D games at 1920x1080).
Now, this projector has the required connector for this, but we still don't know if its inside electronic and firmware can handle this resolution and refresh rate together (still no 3D Vision support, but that could be possible later)
So that would be great if you could make this test (please!) :
- connect the projector to a computer with NVidia graphics, using a DUAL LINK (required for 1080p at 120hz) DVI cable (like the Belkin F2E4141B10DD or other brand), I repeat : a DUAL LINK DVI cable
- use Nvidia Control Panel to create and test a "1920x1080 at 120hz" custom resolution, and let us know if it's working (or just going black)
Thank you !
Edit : just saw your "simultaneous" post and it seems that you're quite aware of this possible feature, sorry
i'm french, and on french forums we still don't know this for sure... i'll report your findingspost #11 of 466210/28/11 at 10:19am- Summa
- Maggie&Monkey Lover!
- offline
- 2,389 Posts. Joined 4/2005
Is Acer not considered a serious "videophile" projector or something? Seems like nobody ever talks about them on here.
I don't know how this thing stacks up against others in its price range, but I've been interested in a DLP with lens shift...I'm interested to hear more about the PQ on this little guy.post #12 of 466210/28/11 at 11:20amThis looks very interesting. Lens Shift, DLP, 3D & priced similar to HD3300. Whats not to like ?
Anyone wants to compare this with HD33/3300 ?
BTW, I can't even find this projector in Acer's website. How can we expect others to take this seriously when Acer themselfs don't even put it on their website ?
Anyone has access to manuals / throw calculations ? ProjectorCentral doesn't have any of this info.post #13 of 466210/28/11 at 11:30amQuote:Originally Posted by evnow
http://www.acer.hr/ac/hr/HR/content/model/EY.JDG01.001 there ya go, but the specs are wrong (lol)
For the manuals: http://www.acer.co.uk/ac/en/GB/content/drivers, go to projectors, H series, and H9500BDpost #14 of 466210/28/11 at 12:35pmQuote:Originally Posted by Mossay
And not in English.Quote:
Thx.
Looks like the lens shift is rather minimal.
- Image can be shifted from 5% offset to 30% vertical offset. But the image will always be above or below the projector. This doesn't help me much in my setup.
- Image can be shifted max 15% from the center using horizontal shift. Might be useful.
Better than no lens shift.
ps : No Vesa port ! So only DLP link ?post #15 of 466210/28/11 at 1:01pmAll that matters here is 1080p 3d using dual dvi if this works it blows away all others period. Input lag below 10ms, epson and optoma 1080p are only for watching blurays. I am so hoping this Acer works so i can play games on a large screen. I will pull the trigger as soon as it plays games from pc in 3d at 1080p 60hz per eyepost #16 of 466210/28/11 at 1:11pm- eat meat
- post count padder?
- offline
- 1,560 Posts. Joined 11/2010
post #17 of 466210/28/11 at 1:13pmQuote:Originally Posted by eat meat
http://www.hdfever.fr/wp-content/upl...2-1024x682.jpg
isnt that a vesa on the right?
Supposed to be rs-232.post #18 of 466210/28/11 at 1:14pmpost #19 of 466210/28/11 at 2:11pmQuote:
True, but if it allows full-res 1080p 3d at a reasonable refesh and little lag, it does look very promising for gamers, and doesn't look like it gives up much elsewhere (except maybe brightness in comparison to the 3010, which may or may not matter much depending on your room).
Either way, it's always good to have more competitive options on the market!post #20 of 466210/28/11 at 3:27pmpost #21 of 466210/29/11 at 3:19amAlso wouldn't mind finding out if the rainbow effect is visible for gaming. My german forum contact says its only visible when on the startup screen (Dark Background, white Acer letters), or when the projector is synchronizing with the computer. I'm hoping this has something to do with the color wheel not using all segments at these stages or something (I'm not too informed about DLP intricacies). I'd hate to purchase it and find hideous rainbowing on games like Alan Wake, STALKER or Metro 2033 i.e. any games that rely heavily on flashlight use in pitch-black settings.
For the record I'm currently using a TW3200(Epson 8350?) and dont notice any lag, but I definitely did notice the step down of 120hz to 60hz when I moved from the acer H5360. Gaming seems to be fine on those Epson range of projectors, but "smoothness" is definitely lacking.
Hopefully with DLP's very low latency if Acer's "AcuMotion" is activated while gaming at 1080p@60hz that it'll look almost 120hz smooth, but remain within the latency threshold where you don't notice a delay when moving the mouse.post #23 of 466210/29/11 at 8:36amQuote:
Tim please give us some feedback on gaming in 3d and the resolutions.
I will be using mine for GAMING and NFL periodpost #24 of 466210/29/11 at 8:36am- dagameballa
- offline
- 160 Posts. Joined 7/2010
post #26 of 466210/29/11 at 9:44ampost #27 of 466210/29/11 at 10:17am- guitarman
- Trader Feedback: +4
- offline
- 12,931 Posts. Joined 5/2001
post #28 of 466210/29/11 at 10:44amQuote:
I don't completely understand this post - but I was responding to your assertion that "All that matters here is 1080p 3d using dual dvi if this works it blows away all others period." - which is patently false (except may be for you personally).
Sounds more like gamer trash talk than something we are used to in AVS.post #29 of 466210/29/11 at 10:52am- ack_bk
- offline
I am guessing if you are using this for lots of 3D you will need to replace the bulb before 2000 hours. Unless brightness is not a concern.post #30 of 466210/29/11 at 11:41amThis sounds like a really decent gaming projector, but for those of us who want really good colors for blurays as well, how does this fair?
Someone mentioned it before, but you almost never hear of people getting an Acer projector on these forums. If I had to award one of the new projectors coming out this winter with the looks like made in China sticker this would be it. I do have a little bit more to spend than what this projector costs, but there seems to be nothing in the $2000-2500 area that offers good gaming performance like this?
If newegg didnt have a "replacement only" return policy on this projector I would test one out and provide input lag screenshots.
OP, can you run this test with a CRT monitor or very fast LCD panel next to your projector and take a photo with a fast shutter speed? http://tft.vanity.dk/inputlag.htmlReturn HomeBack to Forum: Digital Projectors - Under $3,000 USD MSRP- The Official Acer H9500BD Thread
AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › The Official Acer H9500BD Thread - Fall's Most Anticipated Blu-Ray Releases
Currently, there are 1544 Active Users
(352 Members and 1192 Guests)
Recent Discussions
- › plasma....it's just not that good. I'm not trolling! 1 minute ago
- › Yamaha CD-N500 Networked CD Player Owners Thread 2 minutes ago
- › MITSUBISHI HC5, new 3D SXRD projector based on HC9000 2500 euros 3 minutes ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 4 minutes ago
- › Battlefield 3 4 minutes ago
- › 2008 Samsung HL61A750 LED DLP owners thread and FAQ 4 minutes ago
- › Official Samsung UNxxES8000 Owner's Thread 4 minutes ago
- › Which Album (CD or Vinyl) Are you listening to now 5 minutes ago
- › Can Antenna TV Come To An End? 5 minutes ago
- › F8500 Recommended Settings Thread..... 6 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
