AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › The Official Acer H9500BD Thread
The Official Acer H9500BD Thread - Page 118
post #3511 of 4744
Originally Posted by megabadd View Post
I will try out a 3d mkv file tomorrow to be sure, but I tested my updated firmware unit and I can confirm that it fixes the SBS screen tearing problem (!!). I didn't have much hope, but I played a good ten minutes of Gears of War 3 in 3d at 1080p SBS, and did my screen tearing test (spinning the camera around quickly) and saw none of the tearing I used to see. Again, I will test with a movie tomorrow to be sure, but it looks like this issue is fixed! Now, this is the perfect projector for me -- we just had to complain a lot until it became perfect.
Do you know which firmware version your projector came back with ?
Would be good to be able to mention that info to ACER, so that they make sure to update to at least that revision.
post #3512 of 4744
I do not know about all this black border problem I have been reading about because I have never seen it and quite frankly I suspect an input setting problem. My unit worked flawlessy here. Matter of fact I am hoping that my returned unit will be very close to perfect for my purposes.
post #3513 of 4744
As I understand it, this is the "only" firmware update available and it is certainly the latest. As a matter of course, ALL companies will update to the latest firmware rev unless there are unusual circumstances; which isn't the case here. If you send your Acer in and ask for the update, you'll get the right one.
Edited by InCali - 7/30/12 at 7:27am
post #3514 of 4744
Attaching my photo of the service menu (the one where I got "really" smart and actually pressed the correct buttons....hooray for me...).
Please see Mike's post #3422 for an explanation. Service Menu.JPG 2342k .JPG file
Mike doesn't think it's the "Scaler Ver.", but note the date??? That's sort of confusing......
post #3515 of 4744
Can you help me to test the black border problem when you get your projector back ? phillyninja sees the same problem as well. I don't know if this is normal or if I should send it back to Newegg. I am hoping more owners would chime in.
post #3516 of 4744
What I'll do is back off on the zoom tonight and see if there's a black border on the white screen. The way I have it adjusted now, there could be a black border and I just can't see it due to the border of my screen. Kinda think Mike is right...probably a setting issue. I'll copy my settings and send them too.
post #3517 of 4744
Thanks InCali. Appreciate your help !
post #3518 of 4744
Also, NewEgg only gives you 15 days to return. You should call Acer tech support, tell them the problem and get the RMA before your time runs out (if it hasn't already). Otherwise, you have to send it in to Acer for repair. If you call Acer customer care, get to level 2 support asap. It's unlikely that level 1 will "be able to help you with your problem if they can just put you on hold for 3 short minutes......".
post #3519 of 4744
Also, my son flew into Altanta on June 30th with his friend for his annual trip to visit his friend's grandparents. He said he thought he was going to melt......it sounded pretty brutal. Fortunately, the grandparents have a shaded swimming hole.
post #3520 of 4744
I will be more than happy to look for it when I get my unit back because I never noticed it before.
On that note I got notification that repairs to my unit are complete and they will send me a tracking number when they get one. So I got on support chat to find out what was done to my unit and this is what I was told:
Praveen Polaki: I have checked the information and found that our technicians updated firmwares, replaced lamp cover latch and also tested HDMI, VGA and composite inputs and made sure that everything work fine.
So with any luck I hope to have my unit Wednesday if I get lucky and it ships out today. Surely no later than Thursday. So far so good.
post #3521 of 4744
im talking to acer and they are saying no firmware is available. please help! what do i tell them? it looks like the support people don't know there is a fix available.
Edited by Vasim Pathan - 7/30/12 at 1:56pm
post #3522 of 4744
Are you speaking with level two support? If not ask them to go there.
post #3523 of 4744
I backed off on the zoom and didn't see any black border unless no picture constitutes a "border". The only settings I could see that might cause something like this were aspect ratio and HDMI Scan Info (I have auto and underscan set) in the Image menu and auto screen??? (on or off don't seem to make a difference) in the settings menu.
post #3524 of 4744
Here are some pics of the black border. I tried overscan, underscan, changing aspect ratio, etc. and they don't do anything. The entire DMD is lit but the picture is not filling it.
DSC03324.JPG 1168k .JPG file
DSC03333.JPG 1146k .JPG file
DSC03325.JPG 1045k .JPG file
DSC03332.JPG 1149k .JPG file
Edited by Ranger - 7/30/12 at 10:42pm
post #3525 of 4744
I will see if I can get a picture of it as well. I tried to look up close and from what I can tell I did not see any pixel structure in the border area itself (not sure if I would be able to see them in black content anyway) that would indicate underscan. I will try out the hdmi settings that were mentioned as well. From looking at your pictures it seems like your border is larger but it is tough to tell without seeing the whole screen as a reference.
post #3526 of 4744
I don't understand what is the problem? is this pb appears after the upgrade?
post #3527 of 4744
That's the same as the Optoma HD33, a small number of pixels around the perimeter are unused.
post #3528 of 4744
This has got to do with some settings. It looks a well defined border and does not give any indication of any malfunction..
post #3529 of 4744
I don't have anything like that. I'd try doing a factory reset and proceed from there without any major tweaking. If that doesn't work, I'd contact Tiger or New Egg. It's Tiger that gives you 15 days by the way....I don't know about NewEgg, but think they only do replacements and not returns....that'll delay you getting the PJ as they have to receive it before shipping you a new one. What I did with Tiger was to buy a new one, returned the old one, and got a credit a few days later. That sped up the process by 3 or 4 days.
post #3530 of 4744
I have the new firmware and have nothing like this so it's not the firmware update.
post #3531 of 4744
Oh yeah.....call Acer support asap and get level 1 off the line as quickly as humanly possible. Maybe level 2 support can help you get rid of it if it's a setting, If not, get an RMA to return it. If they give you any $#!T, tell them other owners on the forum aren't having the same problem.
post #3532 of 4744
I have a tracking number and mine is scheduled to be back here tomorrow. I do not even need to think hard after looking at the pictures because I can say with certainty that mine did not have a border like that before I sent it in. I would have seen that right away. As for the other things I sent my projector in for, we shall soon find out.smile.gif
post #3533 of 4744
I think this was asked already Ranger but did you verify that the border is there when viewing other sources? Like trying a different Blu-Ray player, VGA connection, etc? These devices have their own overscan settings.
post #3534 of 4744
I will try a factory reset tonight. I got a RMA from Newegg few days ago and have 14 days to return for a replacement.
post #3535 of 4744
I tried level 1 support few days ago and couldn't get anywhere. They are useless mad.gif
post #3536 of 4744
I tried 2 different blu-ray plays, different hdmi cables, WDTV Live media player, HDMI input 1/ input 2 and they are no go. I can try components and VGA tonight.
post #3537 of 4744
post #3538 of 4744
Originally Posted by HiFiFun View Post
Acer second generation LED laser. From China:
http://www.microsofttranslator.com/bv.aspx?from=zh-chs&to=en&a=http://projector.zol.com.cn/307/3077075.html
is it really second gen?most every one will have one by next(optoma ,viewsonic ect.) year,we win in any case.
post #3539 of 4744
using life short is most fatal of problem
period of bulb expenditures is all projection user of heart disease one
post #3540 of 4744
Looks darn similar to H9500BD, chassis and remote as well.
No lens shift though..
