Originally Posted by Digital_Chris
Just to requote myself here...
...well, it has.
And to be honest, yes, all of this technical mumjo jumbo IS incredibly informing, don't get me wrong, but it is also driving me crazy because I just won't be able to apply the recommended absorbtion, which has been pulled forth only because of theory and others (Toole, etc) testing, it seems. How come I haven't seen anybody post for me that they've tried the thin panels, then went to thicker panels and were,for a lack of a better phrase, blown away? Atleast, that's what I expected, instead of test data only from the extreme audiophile. To me, it's almost like saying, "The new Honda Civic get's 2mpg more than last years model" Will we honestly notice it, I doubt it, but the test data is there to prove it. Bad anology, I know, but it serves the point.
Please, to all of you (Local, FOH, dragon), I'm not getting aggrivated at the awesome knowledge that you guys are providing me with, but instead, I feel like you are missing the point that I have a small room and can't give up the real estate for thicker panels, and instead of trying to find alternatives or give me other recommendations, all I get are facts and statements that, in lamens terms, sound to me like "you must do it this way or else your room will sound terrible" or "the only way to make your room sound good is to follow this procedure for treatment".
Sigh.. I'm sorry
Maybe I can postpone this thread for now untill I do some measuring and see where and what my problems are exactly, maybe that will help you guys get a better idea on some alternatives for me
...well, it has.
Sigh.. I'm sorry
Sorry, but there is a thing called physics that determines the objective behavior of sound.
What shortcuts and compromises are acceptable to YOU, I cannot ascertain.
And like another thread where we were supposed to determine what another would "prefer", that is Your job to determine.
Determining an acceptable degree before which an analogous ill fitting pair of shoes becomes unbearable is not a goal to which I have spent my time studying nor aspiring.
Nor does the example of Lee Iococa and the Ford Pinto and the 'acceptable' compromise whereby retrofitting them with a $3 plate to prevent the differential from puncturing a gas tank resulting in the incineration of 'a few' where the calculated losses were projected to be less than the cost of retrofitting the cars seem an solution to be emulated, despite the fact that one hopes that no one would spontaneously burst in to flames due to bad acoustics...
And despite Don Davis' observation that "If bad sound were fatal, audio would be the leading cause of death", it is at least hoped that there are not an excessively large number of fatalities as a result of acoustics.
But you seem to feel the need to make improvements, but for whatever reasons, are not willing to do the job completely. And that is of course one's choice. And a very common one at that.
So why don't you tell us at what point the acoustical behavior becomes unacceptable? And please do so in an objective manner that can actually be gauged. (...and yes, this is a common criterion generally referred to as "proof of performance" in major contractual projects.) If you can do that, perhaps we can suggest the biggest return on your investment in terms of time, effort and money spent.
And despite the acknowledged practical limitations of such issues as thick porous absorption, you don't seem very motivated to pursue the design and/or utilization of more complex alternative products as apparently those are also our responsibility to anticipate and to design as well. But if you are a bit curious, I might suggest a perusal of the RPG website in order to get a pretty good overview of some of that alternative treatments to common porous modal and specular absorption that are available.
So exactly what tradeoffs are you willing to make? Please specify this with objectively verifiable limits. As I suspect few are willing to spend their time designing an amorphously stated moving target where the optimal is eschewed, but for which the problem remains, well, a problem.
Treatments can easily be designed to fall short of the optimal. So, please, tell us in what objectively determinable performance areas and to what objectively verifiable extent is it acceptable for the performance to fall short?
Quite frankly, the 'the optimal behavior as defined by physics is excessive, so what is a median acceptable level of dysfunction' line of reasoning is a bit unusual as a design concept. Except to say that life is full of compromises...
The fact is, it seems that your request is ready made for almost any of the one size fits all solutions that are readily available almost anywhere you look. They all in one manner or another deal with modes and reflections to 'some' degree. Some of them are even very pretty and aesthetically pleasing. And if one installs a popcorn machine that may improve on the acceptability all the more. ...At least one needn't worry about having to listen to their stomach growling...a small but tangible advantage!
The treatments most likely will not be optimal. But hey, if one fails to even take the time to objectively measure the behavior in one's space there is the consolation that one lacks an awareness of exactly what needs to be addressed, and thus any shortcomings are apparently acceptable as at least they lie below an objective awareness. One just needs to decide what price point is acceptable.
I just find it rather schizophrenic for one to complain regarding the existing level of behavior, and yet to also object to objective measures as to how and why behavior can be objectively mitigated.
But rest assured, the industry is literally dominated by those who are more than willing to sell you an incomplete solution. Take your pick. The fact is that deciding amongst them simply due to their sheer numbers will make the choice yet one more dilemma you have to face. ...But at least you can't complain of a lack of selection!
That is your alternative.
But if you can, please generate objective analysis of what is actually happening, and from this we can identify the actual issues and establish a hierarchy of issues that should be addressed, and hopefully you can at least cherry pick the most egregious issues to be addressed.
And lest you fault me for the observation, read one of Toole's own conclusions from the document quoted from a bit earlier:
"However, there is no doubt that the majority of people in the audio business do not know most of the facts and techniques you have just read about. They rely on the roll of the dice, or purely subjective trial and error, to get good sound. Often they do not succeed. This is not an acceptable way to run a business, much less an entire industry.
Given that the room is the final audio component, and it is the one over which the audio manufacturers normally have no control, any improvement is a tremendous asset to both loudspeaker manufacturers, and customers..."
That's the big family system, I've got a nice, fully optimized system for my enjoyment, recordings, editing, etc.
, a staffer at our resort suggested we check out this outdoor club because of their killer sound system. We had prior plans, so we sacrificed significantly to go that night.
) the act takes the stage and begins jamming, at a low level,.... into this sweet, percussion heavy reggae instrumental. Not bad I thought. Then they welcome everyone and launch into their first tune. Wow, I was blown away. Full tilt, extremely loud yet ideally spendid and smooth sound. I was slack jawed in disbelief,...looking again at the PA. Wonderfully full bass, yet perfectly tight. The sound was refined, crystal clear, every detail was fantastic,...I was amazed as it washed over me. Clearly, the system was nearly perfect wrt signal/time alignment. The big, huge reggae bass was perfectly delineated. These players, very good,...a pleasure to watch them perform their craft. Even the vocals sounded very good,....this was a genuine treat. Point being, I simply forgot about the gear and spent the next couple of hours enjoying some of the best live music I've ever enjoyed in my life. Clearly, if you've ever heard reggae music, the rythym section,...the bass guitar and the drums, are often featured prominently. Well, live, it's all about the bass. Fortunately, outdoors, you can get away with huge amounts of bass, without muddying up the rest of the mix. It was huge, full, impactful, tight,....I couldn't believe it, truly speacial for me.
What a night. Does it apply here, for Chris? Hell I don't know, I doubt it,...I just enjoy sharing that story. Under a starry night, killer sound w/superb bass, outdoor live reggae in Negril Jamaica, right at the waters edge.
