Originally Posted by
Digital_Chris
So, my OCD kicks in and I end up doing SO much research on every aspect of my theater, it is overwhelming, to the point of finding contradicting evidence. What I have researched the most is how to treat early reflections and bass peaks/nulls. So much that I have found some ppl say 1" thick is plenty to calm down those reflections, others say 2" is a minimum and 4" is better, on top of that, space it away from the wall, yadda yadda.
Now, I am almost ready for drywall and have a few ideas on how to treat my early reflections. My first plan was to cover all walls with fabric panels, something like this... (IE wouldn't show the lines in between each panel correctly, try to picture 12 panels there)
Each wall will be covered with 1" fabric panels, and I will have OC703 or equivelent behind the "problem" areas (found using the mirror trick). This way, you won't be able to see the reflection panels. Now, since my room is small to begin with, I can't afford to loose too much more, if any, space.
I would like your opinion on whether or not 1" thick absorbtion will be "good enough" for the early reflections or if 2" or larger is DEFINITELY the recommended. If so, I will have to do some funky in-wall panels, but trying to keep this simple. I will also be treating the rear corners with superchunk style bass traps. I know the thicker the panel or more space behind the panel, the lower the frequency it will take care of, but, I just want to make sure I'm getting good imaging and front sound field without going completely overboard.
Also, I'm not trying to make the room a perfect sounding room, that would drive me CRAZY trying to figure that out. Instead, just the main problem areas (early reflection points and corner bass).
