AVS › AVS Forum › Audio › Speakers › BIC DV-62CLRS vs. BIC FH6-LCR Center Speaker?
post #1 of 4
I just purchased a pair of these last week:
BIC America DV64
http://www.amazon.com/BIC-America-Ve...9910635&sr=1-3
They're very nice. Replaced my smaller Athena Audition bookshelf pair. I really liked the look of the Acoustech line, but with my current budget, I just couldn't afford the towers. Plus, my current receiver is a Panasonic SA-XR55 which is only 100W per channel, so I figured that wouldn't be powerful enough to take advantage of the Acoustech line.
Anyway, the FH6-LCR center channel speaker is only $10 more than the DV-62...I'm wondering if it might be better to get that one instead? Or is it important to stick with the DV line since those are the tower speakers I got?
Here they are on Amazon:
DV-62 (MSRP $269)
http://www.bicamerica.com/showpage.p...pe=6&spkrID=41
http://www.amazon.com/BIC-America-DV...9910635&sr=1-1
FH6 (MSRP $329)
http://www.bicamerica.com/showpage.p...pe=6&spkrID=83
http://www.amazon.com/BIC-FH6-LCR-6-...9911240&sr=1-1
The biggest difference I see is the horn tweeter on the FH6...I don't know too much about those though.
post #2 of 4
I had the dv62lcr and sold it for the bic vk6-lcr. You can get them cheaper than amazon and I liked the sound better. I found the dv to be on the bright side.
http://www.amazon.com/gp/aw/d/B001DT...0562502&sr=8-1
post #3 of 4
Would the BIC DV-62CLRS be an upgrade over my Bic HT-65?
post #4 of 4
BIC America DV64
DV-62 (MSRP $269)
FH6 (MSRP $329)
Stay with the DV series center. Unless your going to sell your DV64 Towers and buy the FH6T Towers then you can get the FH6 LCR. Personally I would've went with the Formula Series as I like horn loaded tweeters better.
  Back to Forum: Speakers
